Coil pack bolt thread size
Old Dec 16, 2007 | 07:12 AM
DaddySS's Avatar
Default Coil pack bolt thread size
Anyone know the thread size and have a good lead on helicoils for the valve covers coil pack bolts?
Old Dec 16, 2007 | 08:07 AM
Hilton's Avatar
Tough Mudder
How many did you screw up? If it's only one I think you'll be ok without it. I haven't replaced the back ones on any car I've worked on.
Like the Meatloaf song goes, "Five out of six ain't bad"
Old Dec 16, 2007 | 09:23 AM
DaddySS's Avatar
Yeah, thanks for the response and you're right, you can usually get away with one or even two. But I am going in there over the next month to replace the PCV hoses and valve, and find one noisy rocker, I thought while I had it apart I'd helicoil the cover threads.
Old Dec 16, 2007 | 10:51 AM
massls1guy's Avatar
I believe it's M6x1.0x38.6.
Old Dec 16, 2007 | 11:27 AM
DaddySS's Avatar
Excellent, thanks so much!
Old Dec 16, 2007 | 11:50 AM
lastcall190's Avatar
Please confirm this once you get in there. I searched and there isn't ONE thread with this bit of info
-J
Old Dec 16, 2007 | 01:34 PM
massls1guy's Avatar
-J
So it has to be on this site already to be true, my bad.
It is always a good idea to double check any info you get here. I believe this is the GM bolt as well:
http://www.sdparts.com/product/12560038/BOLT.aspx
Good luck.
Old Oct 6, 2020 | 09:25 PM
rachelelizabeth's Avatar
Default Part number for the bolt
I have a 2001 3.8 camaro missing the bolts on my coil pack and I can’t figure out the size of the bolts
 Michael S. Palmer
Old Oct 6, 2020 | 10:36 PM
Measure the threaded hole, figure the length, and go to the hardware store in the Metric hardware section and get some that look close, varying sizes so one will be it.
Old Oct 7, 2020 | 12:38 AM
Was you answering me or him? Cause I’ve tried everything, even taking the coil pack and putting different bolts in it.
Old Oct 7, 2020 | 01:03 AM
I'm answering you. This thread is over 13 years old.
Old Oct 7, 2020 | 01:04 AM
Go to a junkyard, find a similar car, and get the bolts you need.
Old Oct 7, 2020 | 04:32 AM
I didn’t even notice lol sorry, but yeah that’ll probably be my best bet
