Any need for vacuum lines on intake with no HVAC?
Old Jun 26, 2003 | 07:28 PM
quickWS6's Avatar
Default Any need for vacuum lines on intake with no HVAC?
I removed my HVAC system, so do I need the small rubber lines on the back of the intake anymore? Thanks!
Old Jun 26, 2003 | 07:46 PM
Smoke_Ford's Avatar
Default Re: Any need for vacuum lines on intake with no HVAC?
Personally, I like my PCV system...
Old Jun 26, 2003 | 08:11 PM
quickWS6's Avatar
Where do these run to the PVC system at?
I am not talking about the larger lines behind the intake, I'm talking about the small one that connects to the intake under the MAP sensor and the line to the brakes. This line runs to the 3 way connector by the PCM and up to a small block on the intake.
Old Jun 26, 2003 | 08:12 PM
Smoke_Ford's Avatar
I have a 98, it is different on my car.
Old Jun 26, 2003 | 09:16 PM
felton316's Avatar
The pcv on the 98 is at the front of the intake. He is refering to the little plastic line on the back of the intake by the map sensor and brake booster hose. If it only controls HVAC, ditch it!
Old Jun 27, 2003 | 03:19 PM
quickWS6's Avatar
ttt
Old Jun 27, 2003 | 06:13 PM
2001CamaroGuy's Avatar
HVAC? whats that?
Old Jun 27, 2003 | 06:22 PM
quickWS6's Avatar
HVAC? whats that?
Heating Ventilation (maybe Venting) And Cooling
This is the heater, A/C, and all the duct work and air pump behind the dash.
Old Jun 27, 2003 | 08:01 PM
needmoremoney's Avatar
NO, remove them! I just did the samething as your doing now. I removed all of it. I just vaccumm caped the back of the manifold.
Old Jun 27, 2003 | 09:11 PM
quickWS6's Avatar
Alright, thanks a lot!
