Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 18, 2007 | 04:13 PM
0235SS93's Avatar
Exclamation Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Last night I installed a ported/polished/bump stop tb, started it up, ran fine! Today, I got out there, I went to start it and I let off the key too early and it didn't start, so when I went to fire it back up, it ideled really rough! Then I shut it off and now it won't start at all!!!!! Plus, the SES light is on!!!!! But it was on before I installed the tb. Any advice or help????
Old Dec 18, 2007 | 04:51 PM
Bad Blue WS6's Avatar
you shouldnt be running any new codes,,(bump stop is conservative enough to not be close to that threshold),,i had the same idle thing when i installed my PNPTB,,,idled funny for a min or two, but mine just went away, very quickly, and i had only my normal code ive had forever (P0480, fan relay), no new codes, just the funky idle. What was/is the code? Did you by chance undo your neg batt, where it had to do the relearning thing?
Old Dec 18, 2007 | 04:56 PM
0235SS93's Avatar
No, and I don't know the code
Old Dec 18, 2007 | 05:05 PM
can u try a PCM reset? (im trying to find instructions, but may take a min)
Old Dec 18, 2007 | 05:08 PM
"if you remove the PCM BAT and PCM IGN fuses w/the key on the on position and wait 30 seconds" (i thought there was more steps for this,,,)
these are under one of the 2 fuse panels under your hood. Car will act super funny when u go to start it,,,its re-learning some stuff when u do this. Im heading home now but will be back on to help once i get there.
Old Dec 18, 2007 | 05:16 PM
0235SS93's Avatar
Ok, well I'm leaving at 6 p.m. but I'll be back late tonight, so I'll try that then!
Old Dec 18, 2007 | 05:55 PM
All 4 connections (2 on teh TB, 1 on the MAF, a nd 1 on the lid) plugged in?
Old Dec 18, 2007 | 10:45 PM
0235SS93's Avatar
yea! idk what it is
 Michael S. Palmer
Old Dec 19, 2007 | 08:26 AM
ScreaminRedZ's Avatar
registered user
Usually when you make a change and then the car doesn't work, it means that it's something you did. That is not always the case though. Don't limit your search for a fix to just the TB. It could be something else and just be a coincidence when it happened. I'd start with the TB (swap the stocker back on) and then go from there.
Old Dec 19, 2007 | 03:53 PM
0235SS93's Avatar
I tried the pcm reset, no luck! Weird, because it started and ran for 5 min. no problem what so ever, no rough idle. I started it the next day, it idled really rough, I shut it off. Now it turns over and hits and hits and hits, but won't start!
Old Dec 19, 2007 | 03:58 PM
bene's Avatar
Trunion King
Check all the connections you disconnected.
Old Dec 19, 2007 | 04:56 PM
0235SS93's Avatar
I checked all the connections! I switched back to the stock tb, but it still doing the same thing!
Old Dec 19, 2007 | 05:25 PM
0235SS93's Avatar
come on someone has to know!
Old Dec 19, 2007 | 05:27 PM
ozzy1 ls1's Avatar
did you check the maf plug you didnt bend any of the pin connectors check all sensors cheers Nav
Old Dec 19, 2007 | 05:31 PM
0235SS93's Avatar
I already checked all the sensors and plugs, now I'm pretty sure it's not because of the tb, especially since I put the stocker back on!
Old Dec 19, 2007 | 06:16 PM
0235SS93's Avatar
could the bump stop mod being over-done cause problems?
Old Dec 19, 2007 | 07:43 PM
crainholio's Avatar
No it can't! You hosed up your car! You seem to like exclamation points! Hope this helps!
Old Dec 19, 2007 | 07:47 PM
2000slpss's Avatar
actually overdoing the bumpstop mod can cause the pcm to throw a code. if the tps sensor goes past 100% it will throw codes. do you have anyway to scan the car for the codes its throwing?
Old Dec 19, 2007 | 07:50 PM
Pntbll309's Avatar
Humor isnt your thing.
But depending on how it was ported may play a little part. If it was ported too large and air can get in under the blade, it will idle higher, as if the blade was open. Reading your problem, Id assume it has something to do with what you unplugged and plugged in. IF the plugs and wires are all fine, and you used the stocker too an its still doing it, that would mean that isnt the problem.Dont limit the problem to just the TB since there are more plugs you undid to get it off. Check the MAF #1 that could be it.
Old Dec 19, 2007 | 07:55 PM
Kage's Avatar
Cool
x2
