last bolt on
Old Dec 29, 2007 | 12:16 AM
0235SS93's Avatar
Question last bolt on
Well, I won't be putting an electric water pump on my car, so an underdrive pulley is my last bolt-on. I have an A4, will I have charging issues? Or should I buy the overdrive alternator pulley? Will the stock belts work with an u/d crank & o/d Alt pulley setup? How much hp loss will there be with the o/d Alt pulley? Should I just get the u/d crank pulley?
Old Dec 29, 2007 | 01:29 AM
Tainted's Avatar
charging issues wont be a problem IF you dont ahve anymore than a stock or near stock stereo.
these pulleys are smaller, so obviously you need shorter belts, tsp has the pullies and belts.
Old Dec 29, 2007 | 03:22 AM
bryan04h's Avatar
if you order the asp pulley they should give the part # of the cable you will need to pick up...you could go ahead and pick up the asp alt pulley that will go with the underdrive pulley...
Old Dec 29, 2007 | 12:32 PM
Matt D's Avatar
Retired Street Racer
Just get the underdrive pulley and don't waste your time with the alternator one. I have all of the bolt-ons with just the underdrive pulley, and have never had a charging issue on either of my cars.
