What to plug LS1 intake EGR hole?
Old Dec 31, 2007 | 12:15 PM
03chevy5.3rcsb's Avatar
Default What to plug LS1 intake EGR hole?
What are you guys using to plug the EGR hole on the LS1 intake manifold?
Old Dec 31, 2007 | 12:16 PM
BANDIT8's Avatar
I Went To Lowes And Got A 1/4 Brass Pipe Fitting And Used Tefflon Tape.
Old Dec 31, 2007 | 12:18 PM
bryan04h's Avatar
here ya go man, it isn't as cheap as making something to plug it but whatever ...and bandit8 who is that chick, i see her all the time on fquick
http://www.thunderracing.com/catalog...&sid=223#P4534
Old Dec 31, 2007 | 12:24 PM
nice, does anyone have pics of it?
Old Dec 31, 2007 | 12:34 PM
Blknight6989's Avatar
Look up speed inc. I got a little piece of metal there i think it was like 5 bucks or something.
Old Dec 31, 2007 | 12:40 PM
2001NBMZ28's Avatar
A 1 3/8" expansion plug from auto zone will also work - you need an air tight seal.
Old Dec 31, 2007 | 12:42 PM
bryan04h's Avatar
i don't know about pics man, all it is, is a plug...are you looking for pics just to make one? im sure one of these guys that have made there own can take it out and snap a few pics of it
Old Dec 31, 2007 | 01:04 PM
OMGWTFBODY's Avatar
I used the 1 3/8" to 1 3/4" It worked well for me. Got it from Orly's for ~2.50$
Tighten with a 10mm socket, good to go.
Old Dec 31, 2007 | 02:12 PM
cool, expansion plug is what I was thinking. I know some guys use a freeze plug.
I was wanting to see some pics of the speed inc. plug but I think I'll just do the plug thing
Old Dec 31, 2007 | 02:32 PM
bryan04h's Avatar
cool man, good luck be sure to take pics and post them
Old Dec 31, 2007 | 04:04 PM
bczee's Avatar
GM sells a plug for the EGR Port.. #12558346
Old Dec 31, 2007 | 04:10 PM
Area 51 Racing's Avatar
Don't GM sell a kit for that?
Old Dec 31, 2007 | 04:33 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
We keep this plug in stock for $16. It was intended to cap the EGR on certain model LQ9 trucks that had some problems with the system from the factory. So it's a perfect fit with no jerry-rigging a rubber freeze-plug into your intake!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jan 1, 2008 | 02:56 AM
bczee's Avatar
You will find reference to the plug in the GM LS1 installation guide..... That is were I first found it.
Old Jan 1, 2008 | 03:04 PM
BlackZ28629's Avatar
if you buy one from anywhere "EGR block off" all its gonna be is an overpriced freeze plug. That's what I was sent...Go find a freeze plug that'll fit..Mine fit nicely.
Old Jan 1, 2008 | 04:54 PM
ramairracer's Avatar
go to any auto parts and buy quick steel its like that putty that guy on tv sells, its epoxy with no mixing, just play with it like play-doh till it gets hot and it will harden to a sandable finish in like 5 minutes
i pulled my TB and put tape inside the intake to prevent it from falling in, and then on top shaped it like the hole, after it set and cured, i sanded it with a small dremel to get it to look clean, but it looks good just like that, its like 5 bucks
Old Jan 2, 2008 | 02:46 AM
Inspector12's Avatar
TT-TECH Veteran
It came on the GM trucks when they did away with the EGR, but kept using the same manifolds etc...
Old Jan 2, 2008 | 03:18 AM
james562's Avatar
http://www.ls1speed.com/cont.cfm?cid=C0000045
2.00 from Speed INC there practically giving it away. Worked awesome for me with a simple air tight seal
I have a 25$ Speed Inc Gift Card available if you want it I can Email it to you for $21.00
Paypal is jamesjmj@yahoo.com
