header installation question
Old Jan 4, 2008 | 07:47 AM
lightemupls1's Avatar
Default header installation question
i bought a set of full length long tube painted hedman headers. will there have to be some sort of custom exhaust fabrication for these to work? do you usually have to have something like that done with any long tube header? has anyone used these headers, or encountered any problem with them?
Old Jan 4, 2008 | 08:47 AM
bryan04h's Avatar
if they are like 90% of the other headers we use, a tsp ypipe should work with it, or a xpipe maybe....you shouldn't need custom work unless you can't get a y to match at all...
Old Jan 4, 2008 | 08:57 AM
teke184's Avatar
they ARE designed for the LS1 engine correct?
only real "modifications" that are needed may be with the AIR or EGR equipment, depending on if the headers came equipped with fittings. next thing would be the Ypipe. stock surely won't fit. so you'll either have to take a chance with an aftermarket one, have one custom built...or better yet go TDs
Old Jan 4, 2008 | 11:33 AM
bryan04h's Avatar
td's would work nicely like teke184 said, if they aren't "race" headers then you will need block off plates for your egr/air(assuming your car is a 98-00) if it is a 01-02, then you would just need air plates
Old Jan 5, 2008 | 07:46 AM
i found the y pipe that hedman makes for this set of headers. summit was sold out and jegs only had one left, i got it. thanks everyone
Old Jan 5, 2008 | 08:04 AM
bryan04h's Avatar
cool man, be sure to pick up some engine mounts and those block off plates
