Wahoo!!! LS6 Intake Manifold
Old Jul 2, 2003 | 04:14 PM
Gold Phoenix's Avatar
Default Re: Wahoo!!! LS6 Intake Manifold
EGR also helps to heat the air on cold start-ups to help atomize the fuel. I had a POS car that the EGR system was rusted, so I just pluged all the lines. The car did crank out more power, but in cold weather it was hard to idle without doing it at 1000rpm. btw, this was a 4-cyl. compact car. I have a 2001 without EGR, but at the same time my cam is smaller to reduce emissions
Old Jul 2, 2003 | 06:54 PM
SmaknaSS's Avatar
I have a 01 M6 SS 335HP package oringinaly, By what means How do you tell if you have a LS6 intake???????????? If I do take the LS6 intake off what am I looking for?
Old Jul 2, 2003 | 07:43 PM
SmaknaSS's Avatar
Anyone?
Old Jul 2, 2003 | 10:04 PM
2000LS1's Avatar
All 2001-2002 LS1/6 powered cars have the LS6 intake. From what I've researched the bottom is flat on the LS6 I believe.
Old Jul 2, 2003 | 11:50 PM
Onyx Z's Avatar
In my attempt to become more mechanically incliended, I was reading, "LS1/LS6 Performance" by, Chris Enders and found out that I, and all 2001 and 2002 LS1's (F-body or C5) have LS6 intake manifolds. Anyway, thought I would share, the book has some good stuff that is tried and proven, so you can learn from others mistakes.
Where can I get this book? I want one!!!
Ryan
Old Jul 3, 2003 | 12:01 AM
BIG PD's Avatar
k...so heres a run down?
97-03 corvettes=no egr
98-00 f-bods=egr
01-02 f-bods=no egr
97-99 corvettes=LS1 intake
00-03 corvettes=LS6 intake
98-00 f-bods=LS1 intake
01-02 f-bods=LS6 intake
LS1 intake as an inward hump on the bottom of it
LS6 intake is flat across the bottom
note:if you buy an LS6 intake off of a vette you will need to get new throttle cable bracket fittings or remove your old ones from your ls1 intake. i used a propane torch as i didn't have time to mess around.
EGR=Exhaust Gas Reciculation-causes expelled gases to return to the intake in order to burn out the excess carbons?
AIR is the thing that helps with cold start ups though i think. i may be wrong about all of this though. it's what i think though.
Old Jul 3, 2003 | 12:17 AM
Z_Man's Avatar
I got it at Borders, its probably easier to just order it online tho. Its a great book to have
Old Jul 3, 2003 | 12:25 AM
Onyx Z's Avatar
Thanks for the reply. What section might it be in?
Thanks
Ryan
Old Jul 3, 2003 | 03:48 AM
2000LS1's Avatar
98-00 f-bods=egr
01-02 f-bods=no egr
Almost...
97-*00* corvettes=LS1 intake
01-*04* corvettes=LS6 intake
Old Jul 11, 2003 | 11:12 AM
forurwife's Avatar
do u have to worry at all when u switch the ls1 manfiolds with the ls6 if u take the EGR off?
Old Jul 11, 2003 | 03:06 PM
2000LS1's Avatar
You will throw a code and won't pass inspection (in Texas at least). But you can delete the code if you have LS1 Edit.
Old Jul 11, 2003 | 03:48 PM
  #32
BurnOut's Avatar
I have an '01 Z28 that was built in January or February of '01, and it has the LS6 intake. When it was in the shop for the H/C setup, I made it a point to look at the intake, and it's flat across the bottom (read: larger plenum volume).
Old Jul 11, 2003 | 07:09 PM
  #33
99 Black Bird T/A's Avatar
EGR=LS1
No EGR=LS6
NOT TRUE!
There are vette EGR less intakes floating around out there. I bought one because it didn't have the EGR thinking it was an LS6 intake. I was lucky a friend thought the base didn't look flat enough. He checked the part number and it was an LS1 EGR less intake from a vette. Cost me $350 to learn this the hard way.
All 01-02 F-Bodies come wtih the LS6 intake no egr
ALL 98-00 F-Bodies have the LS1 intake w/egr
Vettes do not have EGR 97 & up. 97-99 & maybe 2000 vettes have LS1 intake without EGR. In case 01 & up vette intakes are LS6.
If buying and intake CHECK the part numbers to be sure!!!
