True Duals Over the Axle: Different Approach
Jason
I want to run mine like the car shown in my first post so I can tuck the pipes higher up in the driveshaft tunnel. Plus this approach would be cheaper.
Jason
Here's mine, similar setup.
Click pic for rest of the set.
You still need room on either side and will want to "relocate" the wire pack on the drivers side seat well. Also need some heat wrap for the brake lines that go over that side aswell. Clearance is still pretty tight, so you'll need a skilled pipe guy to get it through those clearances without banging on the serious bumps.
Mine bangs some now as it is. Its tough, those clearances are small, I'm only 2.5" over the axle too.
The guy I had do it kindof wanted a challenge too so we went with it.
It was either that or straight out, which would also have worked with those glasspacks.
I actually might remove that whole section at the flanges and go out the back without the mufflers cause right now its really pretty quiet.
I also started it last night to see how it would sound as is. It will be 100% this friday. Then I will grind all the welds smooth,install the v bands and put it back on to make sure it doesnt leak. Then off to coating.
This is how quiet it is. Mind you this is a 402 with the aps twin kit.
video:
http://s7.photobucket.com/albums/y25...RAMMY_0001.flv
