cam help please
I have a 00 TA with 64K. Full suspension, lid, borla catback.
Pacesetter Longtube headers
Pacesetter off-road connection pipes
S cam- 238/240 on a 112 LSA 605/609 lift
Comp Cams *NEW* .650 lift 918 valve springs
Comp Cam 7.400 pushrods
NGK TR6 Spark Plugs
160* thermostat
Mobil 1 oil change
Price: 2076.12
1 day turn around time, installation and tuning included.
My questons are:
1. For the price is that a good deal, and if not what should I be looking at paying?
2. Next, I hear that the stock lifters and rockers should be more then suitable for my needs. Also, I was thinking of keeping the stock timing chain instead of going double roller. Is that a good idea, or do I need to replace it?
3. I really want a safe setup that I won't have to be worried about problems or driveablility issues...With this package on a mostly stock vehicle, will my car be safe? I plan on going Fast 90 this summer when my friend sells his to me.
Thanks,
Brian
I also agree you need to add in a ported LS6 oil pump and LS2 timing chain. Also, why are you going with colder plugs on a NA set-up?
if your car is an a4, get a stall!! if it is a m6 try upgrading the flywheel to aluminum and a stronger clutch......possibly check out some gears in the back to help the accel.....that is a strong set up man! As far as clutch is concerned, it has a fresh ls7 in it, and already has an aluminum flywheel. I like the stock gears because I do a lot of freeway driving and I'm a big fan of the low rpm sixth gear.
Also, time for my newb question, what do you mean by why am I going with colder plugs? Can someone please explain that to me?
Still, though, should I be alright with stock intake for now (I know it won't be its full potential) and won't be getting the air it should...just making sure it would be safe to run it. Also, how about running the stock lifters and rockers? Good or bad idea?
thanks.
the ngk tr6 plugs are usually for nitrous or blower set-ups, n/a set-ups usually run ngk tr55(or whatever they are called) plugs
Thanks
