No spark on the #2 coil
Old Jan 17, 2008 | 08:51 AM
Prin's Avatar
Default No spark on the #2 coil
A friend of mine did a ls1 swap on a 3rd gen Camaro. It runs, but there is no spark on the number2 coil. The connector haas power, but no spark signal going to it. Ay suggestions?
Old Jan 17, 2008 | 09:40 AM
MM98's Avatar
Try swapping coils, if it works then you know you need a new coil.
-Mike
Old Jan 17, 2008 | 10:01 AM
Prin's Avatar
We did that and we changed the plug wires. Still no spark...
Old Jan 17, 2008 | 12:14 PM
MM98's Avatar
Have u put a spark tester on to see if it's actually sparking, what about the spark plug itself, changed it?? Also are ur sure it's getting fuel as well??
