Solid Motor Mounts
Old Jan 17, 2008 | 12:23 PM
badaSS346's Avatar
Default Solid Motor Mounts
I am thinking about putting solid mounts in my car cuz even with poly mount my exhaust still hits and the headers hit the k-member. Im not worried about vibration and such. I am trying to get this car in the 10's this year. Last year it ran a 11.2 at 123ish. There is no cage in the car and i know i will be thrown out. what im worried about is that if the car bites like it should this year with no cage and solid mount will the frame twist?
Old Jan 17, 2008 | 02:55 PM
BLACK2001SS's Avatar
I'd stick with the GM mounts the Poly mount tend to be verry stiff and take a shape and dont form back into shape like rubber does IMO.
Have you looked at mufflex exhaust hangers http://www.mufflex-performance.com/
I'd be concerned about twisting If I was in the 10's
Old Jan 17, 2008 | 03:02 PM
1CAMWNDR's Avatar
Get the solid mounts. I doubt the frame will twist. Especially if you have SFCs already.
Old Jan 17, 2008 | 03:03 PM
jermzz's Avatar
I dont think you will have enough power to twist your subframe
get some good subframe connectors and poly motor mounts and you'll be fine. No need to go solid unless you just want them to have them.... You can adjust the exhaust to not hit the floor. I was pushing around 550 rw with this combo and never had a problem.
Old Sep 12, 2008 | 08:47 AM
badaSS346's Avatar
i need to bring this back from the dead lol. Anyway...I wasnt gonna do the solid mounts untill i lowered my car...i scrape everything so i am going to tuck my exhaust in a little closer, actually really close so i want to do solid mounts so my exhaust doent move. Will the solid mounts give me false knock?
Old Sep 12, 2008 | 10:05 AM
TheSilverOne's Avatar
no they won't
Old Sep 12, 2008 | 09:08 PM
OUTLAWZ RACING's Avatar
The sphon is the one I have and the push the motor up a bit. I also can remove my oil pan with out rasing the motor LOL!
Old Sep 15, 2008 | 07:47 AM
badaSS346's Avatar
Enough that i am going to have to remove my STB?
 Michael S. Palmer
Old Sep 15, 2008 | 08:25 AM
outkast6991's Avatar
mine moved the motor up maybe an inch. everybody said not to run solids but they were wrong. if i don't tell people they don't know unless i have change in the cup holder. i can't see a way that you'll have problems with your stb
Old Sep 15, 2008 | 08:55 AM
Lt1Porsche's Avatar
solid motor mounts are the best. I had problems with the exhaust hitting the floorboard. Tried adjusting everything and couldnt get them to stop. Put in solid mounts and no noise at all. Like stated above, change in the cup holder can drive you nuts but other than that not much was changed. Just a little vibration. I say go for it. It also cleans up the engine bay really nicely and makes working on it that much easier.
Old Sep 15, 2008 | 11:44 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I've got solid mounts as well and love them
Old Sep 17, 2008 | 08:45 AM
badaSS346's Avatar
Here is a thought...if it moves the motor up an inch...what about header fitment?
Old Sep 17, 2008 | 10:13 AM
x2......muscle car feel fit for a muscle car
Old Sep 17, 2008 | 10:20 AM
i doubt it's an inch. my headers fit fine with solids.
Old Sep 17, 2008 | 10:40 AM
2QUIK4U's Avatar
Where did you purchase the solid mounts?
Old Sep 17, 2008 | 01:51 PM
Z28/2002's Avatar
Spohn makes them and most of the sponsors sell them
Old Sep 17, 2008 | 04:48 PM
on my car it was almost a full inch, but my stock mounts were completely trashed. i could almost pull the rubber insert out without seperating the clamshell. i've read it's a little more than a 1/4 on most cars though. when i first fired it up after the swap the exhaust was pinned up against the floor. solids are the way to go
