Header Gaskets
Old Jan 19, 2008 | 03:40 AM
01T/A's Avatar
Default Header Gaskets
Im about to have my hooker Lt's installed but i still need to order the gaskets. Is there specific gaskets i could get? what would you recomend? and are they expensive? thanks.
Old Jan 19, 2008 | 08:25 AM
fortmyerspolice's Avatar
stock gm gaskets, depending on how many miles you have you could reuse the stock ones if you wanted.
Old Jan 19, 2008 | 11:23 AM
ScrapinBye's Avatar
I got Percy's Seal-4-Good Gaskets from the WS6Store when i put my Pacesetter LTs in. They're a "dead soft" multilayer aluminum gasket, and are supposed to be the best you can buy because the soft aluminum will crush and compress giving you a better seal. And they're about $35 for the set. --Justin
Old Jan 19, 2008 | 11:24 AM
RedRallyeZ's Avatar
i got the percys seal-for-good from ws6store. those have been great so far
Old Jan 19, 2008 | 11:27 AM
Juicedz28's Avatar
Would certian ones build or lose compression?
