Is It Worth It?
Old Jan 22, 2008 | 09:51 PM
Zero4488's Avatar
Restricted User
Default Is It Worth It?
Is it worth it to port the stock tb, remove the bump stop, and do the epoxy mod? I have the following mods and I'm wondering if it would be any noticable difference or any difference at all....
2001 WS6
SLP LM1
SLP LT's w/ cat'd Y
SLP CAI w/ lid
ASP Pulley
I also have a few other mods that don't have to do with the motor, I'm just wondering if I will gain anything from the tb modification....
Old Jan 22, 2008 | 10:21 PM
LS1 Terror's Avatar
its a good add on. the engine will get a better increase of airflow and whistles nice on startup
Old Jan 22, 2008 | 10:25 PM
Zero4488's Avatar
Restricted User
So thats one vote for me to do it....
Anyone else have an opinion?
Old Jan 22, 2008 | 10:33 PM
WhosNXT's Avatar
Yes its definitely worth it. Many people have gained 7-10 hp from porting the stock tb, and with this mod being free that makes it even more worth while. Go for it bro!
Old Jan 22, 2008 | 10:35 PM
Zero4488's Avatar
Restricted User
Alright...I just gotta get some supplies to do it....
Old Jan 22, 2008 | 10:36 PM
tmaschm's Avatar
If you got the means then why not?
Old Jan 23, 2008 | 03:07 AM
green28's Avatar
The little bit of added throttle response, plus the 5-10 Hp increase is worth it in my opinion. Especially if you do it yourself, hard to beat that for the price.
Old Jan 23, 2008 | 08:19 AM
EPMD's Avatar
Default Throttle body
Does anyone have a link to a good thread or article on porting & polishing a TB. Did a search but get too many results. Thanks
 Michael S. Palmer
Old Jan 23, 2008 | 08:43 AM
Bad Blue WS6's Avatar
do some research on that epoxy mod b4 you do it,,,it shows no gains, and can create alot of problems.
https://ls1tech.com/forums/generation-iii-external-engine/781886-do-not-epoxy-your-tb.html
Old Jan 23, 2008 | 09:12 AM
ballhawkdawk's Avatar
post 22
https://ls1tech.com/forums/showthrea...5&page=2&pp=20
No slight against you, but i've seen people complain that the search function is useless. i beg to differ. just play with the words.. i typed in "port own TB" and through a link in one of the threads, i found that post. im sure it's stickied somewhere as well.
Old Jan 23, 2008 | 09:54 AM
Zero4488's Avatar
Restricted User
https://ls1tech.com/forums/showthread.php?t=781886
Alot of people are saying it works....I think it's just the way you do it....
Old Jan 23, 2008 | 10:02 AM
plaf713's Avatar
its def worth it to get your stock tb ported or to port yourself, and to do the bump stop mod, i would stay away from the epoxy mod though as stated above.
Old Jan 23, 2008 | 12:49 PM
ReFtheMC's Avatar
Everything sounds good, except that epoxy thing. Try a search for that picture with the epoxy in the engine....
Old Jan 23, 2008 | 01:08 PM
Carter01's Avatar
Just recently ported my TB (didn't use expoxy) and have no complaints. The seat of the pants meter is a noticable difference and the throttle response has improved also. Awesome mod for the money!!!
Old Jan 23, 2008 | 01:18 PM
yeah,,,they still look bad *** without epoxy, and if its not givin you any gains,,,then why chance it..just be sure the sharp edges are smooooooothed out real good,,blend in those harsh corners
Old Jan 23, 2008 | 01:23 PM
Midnight02's Avatar
Another vote for porting the stock TB and the bump stop mod. I paid Vengeance to take care of mine while it was doing some other work on the car and feel like it was well worth what I paid for it!
Old Jan 23, 2008 | 01:39 PM
99mongooSS's Avatar
explain to me what the epoxy mod is?
Old Jan 23, 2008 | 04:48 PM
Zero4488's Avatar
Restricted User
the epoxy mod looks like this....
