Bad thing happened when swapping O2 sensors...
So I was changing the O2 sensors in the car and when I went to pull the unit out of its 4-wire receiver, the wires came out the OTHER end (the end closest to the wire harness. So now I'm kind of stuck. How do I get those four wires back into their harness? Thanks!
look at the plug on the other side... there should be at least 2 wires that r the same color on both sides. and maybe the wire colors on the sensor r the same too. after that, then push the wires back into the plug. and maybe put some kind of glue on the back side of the connector to hold the wires in place.
