the spark advance free mod???
Old Jan 24, 2008 | 01:20 AM
z28berryhill's Avatar
Default the spark advance free mod???
i heard that you could do somthing with the plug that goes onto the are filter lid and make like 2 advanced on the timing....if this is true what do i do exactly
Old Jan 24, 2008 | 01:41 AM
noone know about this?
Old Jan 24, 2008 | 01:58 AM
LilJayV10's Avatar
You might be talking about the IAC sensor. I know on LT1 cars you could either hook the wires together or put a resistor in place of the plug. The computer would "think" the air is cooler and would add more spark advance. I have no idea if that works on the new LS engines.
Old Jan 24, 2008 | 02:06 AM
Twigs's Avatar
http://www.installuniversity.com/ins...sity/index.htm
Trick the IAT sensor to thinking its 57 degrees out, providing the best(I'm assuming, I have no experience with this) temp for your PCM
Old Jan 24, 2008 | 02:09 AM
thanks also do you guys know of any mods that they do not list??
Old Jan 24, 2008 | 02:17 AM
rodcpierce's Avatar
that mod will work, assuming you have no knock from the factory (highly unlikelly). Every stock tuned PCM I have seen has some degree of KR. So IMHO, this mod is worthless, as if you add 2 degrees of timing to an already KR'ing engine, its just going to pull it right back out.
