Air Pump Fuse?
Old Jan 24, 2008 | 04:37 PM
TFRO's Avatar
Default Air Pump Fuse?
I had seen on here that I need to remove my air pump fuse after I took off my Air/EGR junk from my header install, Is this true or do I need to leave the fuse in?
Old Jan 24, 2008 | 04:40 PM
NHRArox's Avatar
by pulling the fuse, your just disconnecting the link that gives it power on start up. i did when i removed mine. put the fuse in my glovebox. i would if i were you just to be safe, but is it necessary.....?
Old Jan 24, 2008 | 04:47 PM
JScamaro's Avatar
I left mine in so I guess it doesn't matter.
Old Jan 24, 2008 | 04:49 PM
2001NBMZ28's Avatar
Doesn't matter if the codes are turned off.
Old Jan 24, 2008 | 04:54 PM
TheSilverOne's Avatar
left mine in there when i did !AIR and removed the codes
Old Jan 24, 2008 | 05:14 PM
Michael02hawk's Avatar
Mine is out, I consider it weight reduction.
ya know, we need to keep the front ends of these cars as light as possilble.
