Jet hot headers
Old Jan 24, 2008 | 07:16 PM
chevrolet02z28's Avatar
Default Jet hot headers
Ok so after having my jet hot headers n yh sitting around for liek almost a year i talked to the guy whos installing them and he wants instructions to make sure theres no hastle bs custopmizing **** to make them fit? does any one have instructions for these damn things i dont seem to have em... if not has ne one had a problem customizing **** on em...? remember this is the jet hot LTS and there y-pipe... got it from lmperformance.....
Old Jan 24, 2008 | 08:02 PM
SOMbitch's Avatar
Get somebody else to install them. Anybody who can do this doesn't need directions. It's so straight forward. Might have to disconnect steering shaft depending on header. Take some time off and do it yourself maybe then you'll know it's done right'
Old Jan 24, 2008 | 08:41 PM
quikz's Avatar
Disconnect spark plug wires
Remove manifolds and stock y pipe
Install headers from underneath vehicle
Passenger side slides in easily
Driver side had to remove the little oil cover above the oil filter to get it in
Install y-pipe
They went in easily for me.
Old Jan 24, 2008 | 11:07 PM
Wingman WS6's Avatar
Passenger side is a breeze!
Drivers side I've heard of people grinding off part of something to make it fit.
I just got a jack under the tyranny closer to the engine and pulled the motor mount off and jacked the engine up a but. Slid in pretty ez after that.
Old Jan 25, 2008 | 08:28 AM
BlackBADaSS02's Avatar
When I installed my Jet Hots, I had to cut off a casting tab off the block to get the drivers side to slide in.
