Who makes the BEST electric exhaust cutout?
were can i buy a dmh cutout i went to www.not-a-sponsor.com but says canot connect to server any help thanks.
Thanks for all the replies! I went ahead and ordered and just installed the Raceready 3" e-cutout. Seems to be of very nice quality. The only issue I had was with the cutout itself. The merge where the two pipes are welded together looked really sloppy inside. There was between 1/2" and 3/4" of overlapped metal. I just took that bitch to work and took a die grinder to her *** to take care of that problem. Other than that, the actual valve and hardware they supplied me with seemed top notch. The ONLY other thing is that they gave me regular nuts and flat washers to mount the thing. I would recommend using either elastic stop nuts OR lock washers (what I used) just to make sure the nuts won't back off the bolts. --Justin
http://www.ls1speed.com/catagory.cfm?catagory=Exhaust and they are a sponsor.
#32
#37
found it
writen up 05-03-2004, 12:31 PM
changing the switch to the ashtray
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#38
DMH!!!! I love mine I use it every day no joke! I like playing with the sound change.
I have heard to much bad stuff about QTp. I do like the cut out pipe (other than it needs to almost be ported lol) but not there electric cut outs.
