Questions About Water Methanol Alcohol Injection - Post Them Here
Old 03-13-2008, 10:27 AM
AIS
AIS's Avatar
Have questions about water methanol injection? Post them here or call us directly at 1.801.447.2559
Old 03-18-2008, 11:19 PM
AIS
AIS's Avatar
Our special is wrapping up at the end of this month. If you've wanted a fender mount water methanol injection system this is a great opportunity to get in on one of our under the hood fender/firewall mount systems.
Have questions or need help, give us a call directly or post your questions here.
Old 03-27-2008, 05:06 PM
94greencamaro's Avatar
On my supercharged LT1 do i spray before or after the IAT sensor?
Old 03-28-2008, 10:24 AM
AIS
AIS's Avatar
When ever possible we want to spray before the IAT sensor and never before the mass air flow sensor.
Old 03-28-2008, 12:00 PM
SippiSpeedhawk's Avatar
This may seem kinda dumb but i'm new to this. Where would one get the water/meth solution to use? And how expensive is it? If it raises the octane 10 to 15 points, could you run the injection constantly to get better performance and mileage? What I'm basically wondering is if it may actually reduce gas bills?
Old 04-09-2008, 12:13 PM
AIS
AIS's Avatar
Here's an article for you to read about the various different common fluids you can use in a water methanol injection system
http://www.alcoholinjectionsystems.c...icle_info.html
As for increasing gas mileage we have not found this to make substantial worth while increases in gas mileage just yet.
Old 04-09-2008, 02:39 PM
ramairJP's Avatar
Hi AIS,
I'm curious as to what testing/experiences you have running water and/or water/meth injection with a nitrous setup. I'm work a lot with the diesel pickup performace arena, and there has always been a stigma about running nitrous with water injection since many believe it will freeze the water droplets in the intake tract. In these cases water injection is primarily used for EGT reduction and water/meth (up to 30-40%) is used for a moderate power increase. For small "dry" nitrous sprays (.125 jets and smaller) I have never witnessed any freezing when used side by side with water injection systems (400 psi injection pressure, up to six 625 ml/hr nozzles), so I have never seen an issue with running them together. In our cases the air streams where the nitrous/water/meth is injected is up to 80psi and range from 100-250F. Again, just wondering what info you may have regarding the safety of using the two together assuming that both are being used correctly.
Thanks!
Old 04-14-2008, 10:17 PM
AIS
AIS's Avatar
Originally Posted by ramairJP
Hi AIS,
Thanks!
Check out our new article on using water methanol injection system with your nitrous injection
Old 04-29-2008, 10:30 AM
AIS
AIS's Avatar
www.AlcoholInjectionSystems.com
Old 05-25-2008, 12:54 PM
AIS
AIS's Avatar
www.alcoholinjectionsystems.com
Old 06-23-2008, 01:57 PM
AIS
AIS's Avatar
Old 06-28-2008, 11:18 AM
  #32
AIS
AIS's Avatar
Quick Reply: Questions About Water Methanol Alcohol Injection - Post Them Here
