umi kmember with solid motor mounts
Old Feb 12, 2008 | 12:12 AM
chetmo's Avatar
Default umi kmember with solid motor mounts
has anyone done this, i look at the k member, and am wondering if the solid mounts will work? Thanks chet
Old Feb 12, 2008 | 06:31 PM
rjkZ28's Avatar
also curious!
Old Feb 12, 2008 | 08:47 PM
chetmo's Avatar
anyone?
Old Feb 13, 2008 | 03:33 PM
a-low's Avatar
Solid mounts will set off your knock sensors.
Old Feb 13, 2008 | 04:17 PM
Coy's Avatar
Coy
Do you have any proof or personal experience with this? Have you ran solid mounts? I have ran Spohn Solids MYSELF and never had any problems with knock sensors.
Old Feb 13, 2008 | 04:29 PM
Black02SLPSS's Avatar
No it will not work because it is designed to work with the stock clamshells. I believe that spohns kmember is the only one available that will work with both. You could always go with poly mounts, which imo are just as good as solids.
Old Feb 13, 2008 | 05:14 PM
2000Hawk's Avatar
I believe thats more of a myth than anything. I have seen a couple people post on here that run solids, and they have no problems whatsoever. No thing i have heard is that it makes pulling your transmission a pain in the ***.
-Joel
Old Feb 13, 2008 | 09:45 PM
TheSilverOne's Avatar
gimme a break. don't spread lies like that.
back on topic. i'd like to see an option for solid mounts.
Old Feb 13, 2008 | 09:53 PM
01slowbird's Avatar
well personally i have had a hell of a time finding a set of headers that work with the umi kmember. i know this is off topic, just thought i would share...
Old Feb 13, 2008 | 10:18 PM
chuckyt1's Avatar
Just got my Spohn solids today. They are going on a Racecraft K member. I don't think you can use solid on a UMI without modification.
Old Feb 13, 2008 | 10:35 PM
chetmo's Avatar
guess i will have to go with polys, what headers have fitment issues?
