A/F ratio Gauge. HElp
Old Feb 12, 2008 | 04:39 PM
Patty_Pat's Avatar
Default A/F ratio Gauge. HElp
i have the autometer a/f ration guage wat wire does the purple one go to? does it go to a pin on the pcm or an 02 sensor? thanks
Old Feb 12, 2008 | 11:39 PM
Transam295s's Avatar
you can run it off the o2 sensor purple wire all day long. Iv done that on 2 cars and never had an issue. Or you can get it from the PCM wire, which is still the purple wire just alot closer to the PCM. I thougt there was a way to get it from the port but I wouldnt do that. Just use a good connections and get it from the o2 sensor. And power from the dash fuse panel.
Old Feb 13, 2008 | 01:58 AM
Patty_Pat's Avatar
ok thanks
Old Feb 14, 2008 | 07:46 AM
radkon's Avatar
Won't do you much good to wire it into the stock O2 sensors since they response band is only about 14~15 AFR. Get a wideband.
Old Feb 14, 2008 | 12:19 PM
Bad Blue WS6's Avatar
mine works fine,,sure,,its not super duper accurate due to being a single band,,but i also dont have 200 to 400 bux to spend on 1 guage either....
you can tap the Purple wire that is in your wire loom that runs along your drivers side fuel rail.
