ati super dampener install question
Old Feb 15, 2008 | 02:48 PM
bumpin_records's Avatar
Default ati super dampener install question
I just got a super dampener and im in the process of installing it. i broght a install tool to install it. My question is the inside lip of the dampener the bolt washer rest on, do it suppose to be all the way flush with the face of the crank nose cause it will not go any further ? thanks
Old Feb 15, 2008 | 07:40 PM
EvilBLK02TA's Avatar
Sorry bumpin- never had to install one on my car, but Nobodys got an answer for this poor guy? give'em a break- at least hes trying
Old Feb 15, 2008 | 08:57 PM
405HP_Z06's Avatar
No, according to the service manual the crank snout should be recessed. This is the note from the service manual:
Important: The nose of the crankshaft MUST be recessed 2.40-4.48 mm (0.094” - 0.176”) into the balancer bore. If the balancer is not installed to the proper dimensions, install the tool and repeat the installation procedure.
Old Feb 15, 2008 | 09:25 PM
Gregory's Avatar
My experience with damper (Not ATI) is that they sit out beyond the crank nose. The back of the damper bottoms out against a radius-ed and machined portion of the crank. Measure the two (crank and dampener) to be sure. You can also call ATI. They have good customer service.
Old Feb 15, 2008 | 09:38 PM
code4's Avatar
No it doesn't go on that far. The face sticks out quite a bit. You should be able to install your belt & see if it lines up properly.
Did you install it heated & with anti sieze? Mine went on really easy.
Old Feb 15, 2008 | 10:40 PM
ati said not to heat the steel one up. and no i didnt use anti sieze. Thanks for your help guys. the engine is out the car with no heads or accesories. Reading this now i know i do have it on right. I just broght the arp bolt for it. thanks again. I installed the water pump to see if it lines up with the balancer and it does. Seems like the arp bolt would be a little longer though.
