catch can pics
Old Feb 21, 2008 | 11:19 PM
  #41
INMY01TA's Avatar
Originally Posted by 405HP_Z06
Gravity isn't the only force in the equation. Pressure, leak down, and engine operating range are the other variables at work in the PCV system. Gravity will not take all or even most of the oil to the bottom of an empty catch can because most of the oil that is carried through the system is in vapor form. Some form of condensing material or filter is required inside the catch can to help the vapor condensate and in-turn collect in the bottom of the catch can. Under long periods of WOT (i.e. open track and road racing) there is sufficient pressure to push most of the oil vapor through an improperly designed catch can and into the intake.
What are you arguing here? That it should be "after the can? You just said in post #34 that it should be "before" the can.
Old Feb 21, 2008 | 11:20 PM
  #42
405HP_Z06's Avatar
Originally Posted by INMY01TA
It is before the catch can. And facing the correct way.
and your point is? I stated earlier I was incorrect about the direction the valve is facing. YOUR PCV VALVE IS POINTING IN THE CORRECT DIRECTION!!!!!!!!!! YOU CAN PUT THE PCV VALVE ON EITHER SIDE OF THE CATCH CAN!!!!!!!!!
Take a little time to read what someone writes before hastily replying.
Old Feb 21, 2008 | 11:21 PM
  #43
RooRnZ28's Avatar
ok, now i'm bustin out the paint skills,lol. is this simple enough?!
Old Feb 21, 2008 | 11:24 PM
  #44
405HP_Z06's Avatar
I'm not arguing anything. In post #34 I state that some recommend that the PCV valve be placed before the catch can, not me. I have repeatedly stated that I have no preference as to which side the PCV valve is placed when a catch can is employed.
Again, before you reply.
Old Feb 21, 2008 | 11:25 PM
  #45
INMY01TA's Avatar
Look at 405hpZO6s picture. It's the same. His hose comes off the valley and into the top of the can, like mine. Other hose goes from lower fitting to intake like mine.
Are you saying he's wrong too?
Old Feb 21, 2008 | 11:31 PM
  #46
RooRnZ28's Avatar
well his catch-can may be different.... but mine is like yours and the baffles are in the top port, therefore they should be connected to the vacuum side
Old Feb 21, 2008 | 11:35 PM
  #47
INMY01TA's Avatar
Yours is set up wrong. Thank you, good nite.
Old Feb 21, 2008 | 11:40 PM
  #48
RooRnZ28's Avatar
hey we're just trying to help... do what you want its your car.
lol, alrighty then
 Michael S. Palmer
Old Feb 21, 2008 | 11:46 PM
  #49
INMY01TA's Avatar
Fwiw, mine has no baffles. I bet if you were to switch yours like mine, you'd notice no difference. Can collects oil, intake stays dry.
Old Feb 22, 2008 | 12:59 PM
  #50
ls1leadfoot's Avatar
hah yea i agree man
this is also good info though....keep it coming
Old Feb 22, 2008 | 01:07 PM
  #51
405HP_Z06's Avatar
It's completely empty? Nothing but a top port and side port?
Old Feb 22, 2008 | 04:44 PM
  #52
INMY01TA's Avatar
Top cap has like a long narrower "tube" attatched inside that extends beyond the lower port internally.
Old Feb 22, 2008 | 04:58 PM
  #53
ReFtheMC's Avatar
radz282003 that is one sick setup
Old Feb 22, 2008 | 05:19 PM
  #54
radz282003's Avatar
Thanks. It took a couple times to bend the brake lines well and I might do the passengers side again but I'm happy with it right now. Shoot, if that set-up doesn't catch the oil I don't know what will.
Old Feb 22, 2008 | 07:04 PM
  #55
01Z0H6's Avatar
This one for the win... Mine is the same, and there is plenty of oil in mine @ each oil change.. $$ well spent IMO..
Funny thread.. thanks.
Old Feb 22, 2008 | 08:02 PM
  #56
RooRnZ28's Avatar
see, this tube is a baffle. open it up and you'll see. you'd get better oil separation if you had them connected the other way.
like i said, just trying to help!
Old Feb 22, 2008 | 08:14 PM
  #57
INMY01TA's Avatar
Perhaps I'll try it that way. Stays dry now tho. I can't see oil traveling in the can via the lower port, running down the inside of the can, then traveling upwards inside the tube/baffle.
Old Feb 22, 2008 | 08:21 PM
  #58
RooRnZ28's Avatar
when the pcv oil/gasses enter thru the bottom port, they come in contact with more surface area of the inside of the catchcan. the top port on the catch can acts as the "filter" and filters out any oil left in the vapors, allowing it to just drip. it will work either way, but this way you get more separation.
Old Feb 22, 2008 | 08:55 PM
  #59
speed_demon24's Avatar
That's a norris catch can, its designed for the oil to go in the top port and condense in the mesh thats inside the tube, then for the air to go out the side port.
Old Feb 22, 2008 | 09:45 PM
  #60
TLewis4095's Avatar
The cans with a perforated tube running down the center work best with the flow coming in through the top center extending to app 1 1/2" from the bottom. And the vacum PCV regulated line pulling the vaors out the upper side fitting. This allows the vapors to evenly disperse out the small holes in the tube and evenly contacting as much inner surface as possible to aid in the condensation of the vaors so the liquid is not pulled into the intake, just the unburnt fuel & combustion gasses that are then burned in the combustion process.
