Question about FTP lid and SLP MAF
Old Apr 17, 2008 | 08:06 AM
Jpr5690's Avatar
Dam Just What I Was Looking For!
Old Apr 21, 2008 | 11:08 AM
noworries's Avatar
Just talked to Fast Toys and SLP. Unfortunately, the SLP 85mm MAF has to have the IAT connector in the lid (or somewhere forward of the MAF), so the neat Fast Toys connector won't solve our problem with that particular MAF. Too bad, 'cause it makes a much tidier installation, and the Fast Toys Lid is really way too pretty to have to drill holes in!
Houghtie
Old Apr 21, 2008 | 11:21 AM
Jpr5690's Avatar
Im Gonna Give It A Try With My Slp Maf.. I Dont See Why It Wouldent Work
Old Apr 21, 2008 | 12:53 PM
SnakeStomper's Avatar
I have the FTP lid & SLP 85mm MAF .... My installer/tuner tucked the IAT sensor under the lid; works the same.
Old Apr 21, 2008 | 01:45 PM
Jpr5690's Avatar
why cant you just use the sensor that is built into the maf..
the only reason the slp maf wouldent be able to read the air temps would be if slp used a maf that didnt have it built in.. the majority of 85mm mafs have built in temp sensors so with the correct adapter harness it should work fine
Old Apr 23, 2008 | 07:48 PM
Jpr5690's Avatar
Update: Tried It And It Works Great
Old Apr 23, 2008 | 08:29 PM
YellowToy/A's Avatar
I put the IAT sensor away from the the radiator heat. I add wire and mounted the stock sensor lower so it would not get hot when the car was not moving. The sensor should not heat soak. If you get a 85 mm MAF get a tune. Ur current one will be way off.
Old Apr 24, 2008 | 11:47 AM
Jpr5690's Avatar
If Your Running A 5 Wire Maf They Already Have A Built In Iat Sensor All You Need Is The Proper Adapter Harness And You Can Plug Your Stock Iat Harness Right Into The Maf
Old Apr 24, 2008 | 11:51 AM
Fast Toys Performance Parts's Avatar
SO the MAF adpater harness worked with your SLP MAF to enable to the built in IAT? Were you able to verify it was working with a scan tool?
Thanks!
Old Apr 25, 2008 | 07:25 AM
Jpr5690's Avatar
Yup.. Logged It With Hptuners
Old Apr 25, 2008 | 11:16 AM
Awesome. Thanks!
