when installin headers..
Old Feb 27, 2008 | 06:07 PM
michaelxx16's Avatar
Default when installin headers..
do i need to use any exhaust wrap on anything? (plug wires, etc.?)
or can i just stickem on and run it? without burning anything up
thanks,
michael
Old Feb 27, 2008 | 06:19 PM
lastcall190's Avatar
Never used exhaust wrap on my plug wires. Just use common sense when you put them on and dont let them rest on a primary. I ziptied mine to the dipstick (thanks stupid EGR tube!)
-J
Old Feb 27, 2008 | 10:07 PM
snake charmer's Avatar
dei makes something to keep them if they are touching but it is a little pricey . like dude dais just make sure they are not touvhing the header pipe and you will be good .
Old Feb 28, 2008 | 06:24 AM
medwar11's Avatar
My Taylor Thundervolt wires are perfect length and don't get too close to the longtubes.
Old Feb 28, 2008 | 06:49 AM
GregWS6&z28's Avatar
stock plug wires would just be plug and play and forget.
ok then, thats the only thing i have to worry about then? the spark plug wires? and also do i need to buy 02 extensions? or no? (headers didnt come with any)also i have a 02 sim. on my passenger side one thats after the cat(i didnt put it on there, previous owner did) should i replace that 02 with one that works? and connect those 2 back up?
Old Feb 28, 2008 | 11:36 AM
ShevrolayZ28's Avatar
I wouldn't waste money replacing the rear sensors. All they do is monitor the cats. I'd just plug them or screw in an old sensor and connect them, then have their codes set to "no report".
You will need 24" extensions to connect the fronts.
Old Feb 28, 2008 | 12:02 PM
WS6_00's Avatar
the boot of two of my wires touches my header ever so slightly..... can I put wrap on that? - the boot
 Michael S. Palmer
Old Feb 28, 2008 | 12:11 PM
2002_z28_m6's Avatar
Nothing touches on my ARH headers. They fit like a glove.
Old Feb 28, 2008 | 12:50 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Wrap your clutch line.
Old Feb 28, 2008 | 12:53 PM
Gordon0652's Avatar
I have installed my headers 2 days ago and i am using the factory plug wires and the boots seem to be touching them, well some of them.
I have put 75miles since the install (love to cruse with the new sound) and the boots have not melted or even left a mark on the headers. I think you should be fine.
Old Feb 28, 2008 | 01:35 PM
sl99ls1's Avatar
gm replacment gaskets and new gm bolts
Old Feb 28, 2008 | 05:49 PM
i was looking at using the stage 8 locking header bolts... because my brother said on his lt1 z28 the header bolts kept backing out of his headers fast when he reused the stock manifold bolts. also would a Fel-Pro gasket from advanced work just as good? (its like layers of aluminum or other metal.. that crimp to seal it up when u tighten it or something..) or should i just get a new GM one?,, also i just got a ls6 intake mani, should i get new seals for it?(intake & TB seals) dunno how many miles are on it.
also.. what should i wrap the clutch line with?(just replaced my slave/master/clutch assembly & flywheel) dont want it messin up lol
Old Mar 1, 2008 | 12:33 AM
Cantalope Kid's Avatar
Jesus cristo' put down the crack pipe! Use thread locker red on the stock bolts and you won't have that LT1 owners backout bolts issue...no get a stock GM gasket from the dealer...yes replace the seals if they are worn...refer to previous source for parts...not necessary to wrap clutch line if you are just careful routing it. Use common sense problem solved.
