tuning out rear o2's
Old Feb 25, 2008 | 08:13 AM
W es 6's Avatar
Default tuning out rear o2's
ok so i got my front o2 extensions in place, and it'll be awhile before i can get my rear o2's tuned out. will the car run like **** until then?
Old Feb 25, 2008 | 08:25 AM
oange ss's Avatar
no...will have an SES light tho..
Old Feb 25, 2008 | 11:47 AM
rayvendawn's Avatar
how much is it to have them tuned out usually?
Old Feb 25, 2008 | 01:36 PM
W es 6's Avatar
don't know for sure... but after looking around on these threads i would say in the neighborhood of $75. just depends where you go and what state you're in. like here in nc we're emission controlled so it might cost me "a little extra"...
Old Feb 26, 2008 | 06:36 PM
SidewayzOZ's Avatar
I wouldnt pay more than $100 to have it done, because youre basically just paying for a license of the tuning software. It literally takes less than 5 minutes to turn the codes off and reflash the car.
Old Feb 26, 2008 | 07:19 PM
Dskeet6's Avatar
rapid gave me a $75 quote
Old Feb 26, 2008 | 07:33 PM
Wsteun's Avatar
Depending on the year of the car its free.
We were able to tune out the EGR & AIR on my 98. 99+ Needs a license.
Old Feb 26, 2008 | 08:08 PM
chromeplated500's Avatar
you can get O2 simulators... for $35 a piece.
Old Feb 26, 2008 | 10:32 PM
rayvendawn's Avatar
lol where at? they are like 100 for two plus shipping everywhere I've seen
Old Feb 27, 2008 | 09:54 AM
radkon's Avatar
O2 sims are illeagal and most places have stopped selling them. Caspers (the maker) has stopped making them after a HUGE fine from the gov't. The only place I've seen them is ebay and used.
Old Feb 27, 2008 | 11:23 AM
LS698ta's Avatar
your car will run rich
Old Feb 27, 2008 | 03:17 PM
96lt1ss's Avatar
The car should run fine, it will just have a check engine light.
Old Feb 27, 2008 | 03:55 PM
tylerdj's Avatar
Rear O2's do not affect your A/F mixture.
Old Feb 27, 2008 | 06:17 PM
Arc00TA's Avatar
Yes, yes they do. Rears are used to check the short term trims. Your car will bounce back and forth between rich and lean and generally feel like ****, and also have 3/4 the power you're used to.
Old Feb 27, 2008 | 08:21 PM
RA4926's Avatar
not having a catalytic converter is illegal too, which is why casper was fined.
so why did i run 2/10 quicker down the quarter after i installed long tubes and COMPLETLY REMOVED (without tuning them out) the rear 02 sensors? front 02's moniter a/f, rear 02's turn on the ses light when the cats are damaged or removd.
Old Feb 27, 2008 | 09:09 PM
Arc00TA's Avatar
When you go WOT all of the OBDII stuff is negated. The 02s do not do anything. Yes, you are right about what they do but the computer uses the rear signal not only for telling if the cats are good or not but to adjust the mixture to allow for the best "burn". I should have been more specific in my last post, sorry. Now, if you unplug the front 02's you will set a hidden code, and you will just run open loop forever, basically what the car does when its warming up.
Old Feb 28, 2008 | 12:13 AM
tylerdj's Avatar
No, no they don't. The rear O2's have no affect whatsoever on the car's A/F mixture, which is why they are able to be tuned or replaced with sims. Their only purpose is to monitor the cats.
Old Feb 28, 2008 | 07:40 AM
radkon's Avatar
QFT, the only function of the rear O2s is to monitor CAT performance.
Old Feb 28, 2008 | 02:57 PM
sl99ls1's Avatar
when i did my long tubes my afr's were all ****ed up then when i got them tuneed out my car ran fine and the guy who tuned them out said the rear o2's should not have no affect on my afr readings
Old Mar 1, 2008 | 12:38 AM
Cantalope Kid's Avatar
WTF?! You sir...are dead WRONG!
