Vats Bypass Help
Old Feb 28, 2008 | 06:27 AM
Sunset SS's Avatar
Question Vats Bypass Help
I am ready to put in the resistor in the VATS connector under the dash on my 2001 SS.
I was thinking the easiest way to do this is to buy a new connector and solder the correct value resistor to this new connector and plug this into the connector that runs to the VATS module (after unplugging the factory connector). This way no cutting or modding the existing harness is done and it would be easy if later in the future someone wanted to return it to factory spec.
DOES ANYONE KNOW THE PART NUMBER OF THE CONNECTOR THAT I NEED TO DO THIS?
Thanks,
Eddie
