Oval pipe flow as good as round?
Old Feb 28, 2008 | 04:40 PM
SuperZ's Avatar
Default Oval pipe flow as good as round?
For example 4inch being 2 3/4 tall and 4 3/8 wide or 3.5inch being 2 1/2 tall and 4 wide? Would it flow the same as a true round pipe with the same overall diameter?
Old Feb 28, 2008 | 04:57 PM
Asmodeus's Avatar
A perfect circle will outflow a non-perfect circle with the same circumference if that's what you're refering to, due to possessing more area. Get the exact sizes of the pipes you're comparing, and from there it's just a little calculus to determine the area inside each pipe. The bigger number will flow more.
Old Feb 28, 2008 | 05:56 PM
Full-Force's Avatar
I strongly disagree with the above and will go as far to say that an oval pipe may outflow a round when it comes to exhaust flow. Think about it.
Old Feb 28, 2008 | 06:16 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I'm thinking about it.
Nothing.
Please explain.
Old Feb 28, 2008 | 06:31 PM
Medic/Z28's Avatar
From SuperZ's calculations oval.
Old Feb 28, 2008 | 08:08 PM
Full-Force's Avatar
Well in a nutshell the flat pipe should flow faster at a higher velocity. I have a set of Micron Serpent headers on my bike and they have a flattened section in them that prevents reversion by keeping the velocity up.
Old Feb 28, 2008 | 08:10 PM
Eatinstang4life's Avatar
Who gives nomatter what its not going to cause power loss you will not be able to feel anything!!!! Maybe like fractions of horsepower.
Old Feb 28, 2008 | 08:13 PM
LS1curious's Avatar
There is less overall area for boundry layer air to accumulate in an oval pipe. It will acctually flow more air at a given pressure.
Old Feb 28, 2008 | 08:17 PM
tcr98taws6's Avatar
Ever look under a NASCAR race car? The pipes are oval.
Old Feb 28, 2008 | 08:20 PM
for clearance
Old Feb 28, 2008 | 08:24 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
EXACTLY...NO POWER LOSS...
Old Feb 28, 2008 | 08:42 PM
99mongooSS's Avatar
Originally Posted by Eatinstang4life
for clearance
yes and no they do flow better and they are better clearance as well. that why some dragsters with upswept headers are using oval merge collectors that turn into ovals at the end.
Old Feb 28, 2008 | 09:10 PM
Asmodeus's Avatar
really? so if I take a 3" round pipe and flatten it it will flow more? That's basicly what you just said.
Old Feb 28, 2008 | 09:49 PM
Gordon0652's Avatar
I want to say no.
But this is an intresting topic, maybe Dr.gas will chime in and help you.
Old Feb 28, 2008 | 09:51 PM
WS6addiction's Avatar
Years ago, one of the car mags tested this on a flow bench. IIRC, they found that given the same cross sectional area, the oval pipe flowed SLIGHTLY better than the round pipe.
That's been at least 15 years ago... Damn I'm getting old.
Old Feb 29, 2008 | 12:29 AM
SuperZ's Avatar
Yeah this is good stuff.Well i want to do the largest single exhaust I can without terrible ground clearance.
Old Feb 29, 2008 | 12:36 AM
porksoda's Avatar
That oval tubing is EXPENSIVE!
Old Feb 29, 2008 | 12:43 PM
SuperZ's Avatar
its B/A though
Old Feb 29, 2008 | 06:17 PM
2002BlackSS's Avatar
It's been a while since I've done any fluid dynamics, but here's a brief rundown for you:
Flow is based on a number of factors, but the primary one dealing with shape is Hydraulic Radius, which is calculated by Rh = dA/dP.
Given the Area of a Circle = pi*r^2, Perimeter = 2*pi*r
And the Area of an Ellipse = pi*a*b, Perimeter = pi(a+b)K, where a and b are the long and short radii, and K = (1 + 1/2m^2+1/64m^4...), where m=(a-b)/(a+b)
Set the perimeters equal (same size initial pipe to be used for circular and elliptical cross sections), so 2*pi*r = pi(a+b)K, which reduces to d = (a+b)K.
Therefore Rhc (circle) = (pi*r^2)/(2*pi*r) = r/2 or d/4
Rhe (ellipse) = (pi*a*b)/(pi(a+b)K) = a*b/d (remember our nice substitution earlier)
If we look at the numbers proposed:
4" circular - Rhc = 4/4 = 1
2 3/4 tall and 4 3/8 wide - Rhe = (1 3/8 * 2 3/16)/(2d) = .7519
3.5" circular - Rhc = .875
2 1/2 tall and 4 wide - Rhe = .625
In both of these cases, the hydraulic radii are decreased by going to an elliptical shape, which would, all else being equal, mean the elliptical pipes flow less than their circular counterpart. This, however, is best determined experimentally, as a number of other factors, such as temperature and pressure differentials, turbulent or laminar flow, friction of the pipe, fittings, etc. all greatly impact the real world dynamics of fluids in a pipe. In other words, depending on other factors, the advantage may go to the elliptical pipe.
Ultimately - in the situation you're looking at, either pipe would provide ample area for the exhaust of an LS1, so I wouldn't worry much about it. Just use what you've got that works.
Old Nov 30, 2015 | 09:07 PM
TexomaMan_X2's Avatar
Mind blown
