Map censor
Old Feb 28, 2008 | 05:41 PM
camAro242's Avatar
Default Map censor
I am changing out my map censor and I felt around the back of the intake and was wondering if there is a trick of getting the damn thing out.
Old Feb 28, 2008 | 06:35 PM
camAro242's Avatar
anyone??
Old Feb 28, 2008 | 07:49 PM
Pro52R's Avatar
try "sensor".....they might be confused
Old Feb 28, 2008 | 09:14 PM
Wsteun's Avatar
There really isn't a whole lot of room to get your hand back there, but if you can, good luck. You'll probably have to pull the intake manifold.
Old Feb 28, 2008 | 09:15 PM
DirtyJohn's Avatar
That ones' gonna suck with it on the car, but you can do it.
Here's a couple pix to help out...
This is what it looks like from the rear..
The MAP is #5 in the pic, and the tab that is holding it down is circled in white.
This...
Is basically what it would look like if you were looking along the back from the drivers side toward the pass side, that clip has to be pushed back toward the firewall and the MAP will lift up vertically.
Its tricky and you will cut the crap out of your arms getting at it but it can be done.
