Epoxied Ported Throttlebody
Old Mar 19, 2008 | 05:15 PM
FMX05's Avatar
Chisel and a hammer.
Seriously, I would try a dremel with a die grinding bit on it. After you get it started just try and chip it away.
From the picture of your pistons up there I though you had the stock LS1 PCV system. Mine is throwing enough oil to make it look like that...
Old Mar 19, 2008 | 10:43 PM
mikenews's Avatar
You could also take a drill bit that is the same size of the brass tubes, insert it and give the drill bit a whack with a hammer, hitting the drill bit on the side, not driving it into the the TB. This should start to break up the epoxy. Glad when I ported mine I never epoxied it!!!
Old Mar 20, 2008 | 02:05 AM
99z28monster's Avatar
had a guy in a local club blow a motor because of that same problem. messed some stuff up for sure
