ARH Header question
OBDII is very sensitive. When you do your emissions testing, always do it with the motor HOT!
And yes it does happen with pretty much any of the header systems, its not just ARH.
Wouldn't that just be a heat issue again? A larger surface area with greater flow rate means it takes more time to heat them up.
We have customers that run cats and all emissions equipment but still delete codes or use sims because they hate having to reset the check engine light for the 420/430 codes. They usually go away after driving a while but it gets annoying.
Magnaflow just put out a TSB on their cats and this exact problem. It's very common.
