Is there any way to test a MAF off the car?
Old Mar 3, 2008 | 01:20 PM
BadgeZ28's Avatar
Default Is there any way to test a MAF off the car?
can a simple test from continuity determine if a MAF sensor is OK?
Old Mar 3, 2008 | 01:38 PM
jimmyblue's Avatar
Moderator
Probably not dead simple, but if you can read frequency
(as some of the better DMMs will) then give it +12V and
ground and a pullup to 5V on the output pin and you
should see a kHz or two which moves some if you blow
on it.
Old Mar 3, 2008 | 07:16 PM
RE AND CHERYL's Avatar
If it's dead you'll get the SES light. Engine will actually continue to run OK as the PCM will revert to the MAP sensor to stay running.
Best way to test it I can think of would be to use a scanner with a live scan feature.
Re'
