Can I Ground The O2 Sensors To The Chassis?
http://www.ls1.com/forums/showthread...p;pagenumber=1
I looked at the wiring diagrams for my ’98 Z28, and the only thing that I can conclude now is that I’ve burned a wire. The O2 sensors only have 2 wires in common, the pink wire (power for the heating element of the O2 I presume) and the black wire, which is for the ground. I don’t think the pink wire is the issue because it also goes to the EGR system and several other emissions related equipment, and they’re not having any problems, so that leaves the common ground as the possible problem.
Can I just splice the O2 ground wires from the front O2’s and ground them to the chassis? According to the diagram I have, the O2’s are grounded to the chassis, not back to the PCM. Can I run a jumper wire, or if the ground is grounding against the headers or something, then that won’t work and I need to completely replace the ground wires and run them to the chassis? I realize the importance of making sure I tap or replace the correct wire, but is there any reason why I can’t ground them to the chassis to see if that solves my problem which would confirm a burned common ground wire?
I can figure out which is the ground from the wiring harness, but the O2 sensors wires aren't the same color. Does anyone know which wire is the ground? Each terminal is assigned a letter, so it's either A, B, C, or D.
