Whats in YOUR can?
Old Mar 7, 2008 | 05:44 PM
unbroken's Avatar
Default Whats in YOUR can?
Catchcan that is.........Question what is a "usual/acceptable" amount to see in a catchcan on a LS1 NA motor? I have 50K ,basic mods etc. I made a home depot catchcan and have started to see some oil on the bottom. A buddy has the same setup and his is half full with about 500 miles on his 2002 w/75K. Could he of put too much oil in the motor?
Old Mar 7, 2008 | 06:07 PM
Omec's Avatar
its not from putting too much oil in. although it could be if you filled it to the brim lol. every engine varies to the next. it also depends on years from what i understand. plumbing wise of the pcv system. ive heard people constantly draining and some that hardly. as long as its not going into the intake it should be ok
Old Mar 7, 2008 | 07:19 PM
2000Hawk's Avatar
I did a home depot catch can as well, but with 2 small husky seperators. Whatever the first one doesn't catch, the second hopefully should get it. Got the idea from a guy in a vette i believe that started a thread on here. I think it varies between cars as well, and i think also on how many times you go WOT in your car. I think if your always hauling ***, and taking your car to 6K (or higher if cammed) you got a larger chance of oil getting sucked up by the pcv.
-Joel
Old Mar 7, 2008 | 08:16 PM
Hilton's Avatar
Tough Mudder
I haven't installed mine yet, so nothing.
Old Mar 7, 2008 | 08:29 PM
unbroken's Avatar
Hmmm, maybe add another one......
Old Mar 8, 2008 | 01:14 AM
2000Hawk's Avatar
I'll see if i take a picture of it tomorrow so you can check it out. I would definetly prefer a catch can, but with low funds i just made this set-up.
-Joel
Old Mar 8, 2008 | 08:09 AM
TLewis4095's Avatar
-Joel
That is deffinatly better than no can, but the plastic does not dissipate heat well enough to condense the vapors. It will catch some of the oil mist & that is wher most of the oil in the intake comes from. Take a look at these when you can budget it...only $69 for all you need:
Good Luck!
Old Mar 8, 2008 | 08:44 AM
black01_WS6's Avatar
did he change out the PCV valve when he did this? if not have him put in the new ls6 PCV vlave that ws6store sells for like 6 bucks. It helped in my situation.
Old Mar 30, 2008 | 08:37 PM
unbroken's Avatar
How many people throw away that little bit of oil? Or do you put it back in the motor?
Old Mar 30, 2008 | 10:44 PM
snake charmer's Avatar
i did away with my pcv pretty much . run a hose to the back valve covers almost like stock . then put a rubber nipple over the front of the passenger side valve cover a nipple on the intake manifold , a nipple or plug on the tb and a breather where the oil cap is and it is good to go . keeps all the unmetered air as well as hot gasses from being recycled back into the intake .
Old Mar 31, 2008 | 05:29 PM
TLewis4095's Avatar
Do NOT put that oil back in!!! It is full of harmfull contaminates such as moisture, unburnt fuel, combustion gasses, etc.
Old Mar 31, 2008 | 05:37 PM
TLewis4095's Avatar
How are you flushing out the other gasses that re-comdense back into the engine after cool down? All it appears you can accomplish w/your setup is to relieve excess crankcase pressure at high RPM's, but w/out pulling metered vac at idle or low rpms the water vapor, unburn't fuel, caustic combustion gasses, etc. all stay in the motor. If it was a track only application then pull vac w/a belt driven vac pump with a vac relief valve in the opposite valve cover that the vac pump would pull from & then dump it into a vented overflow can (so none is spilt on the track) and you would be OK there, but you will shorten your motor life quite a bit with the setup you describe over time on the street. Also, where does the hose run to from the back of the valve cover? If unfiltered it is a direct path for dirt & moisture into the crankcase. A PCV system set-up properly with a functional catch can will eliminate all but the worst blow-by oil contamination.
Old Mar 31, 2008 | 07:21 PM
03Sssnake's Avatar
TLewis, that is a sharp looking catch can, I just may have to pick one up. Do you recommend installing the PCV valve inline and upstream from the can, or leaving inline after the catch can?
Old Apr 1, 2008 | 09:12 AM
TLewis4095's Avatar
It can work either way. Earlier F-bodies have the PCV midway back along the valve cover & corvettes & later model F's have it right before the intake vac source. The key is that there is one....and it's always a good idea to put in a new one as they get gummed up over time.
Old Apr 1, 2008 | 10:55 AM
RoDan's Avatar
I normally have a little bit of oil mixed with quite a bit of water, nasty stuff.
Old Apr 1, 2008 | 11:11 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I put a couple thousand w/ regular 5-30 dino oil, Id get maybe a half cup at best.
Old Apr 1, 2008 | 11:17 AM
bigfatls6's Avatar
TLewis4095 does this kit include directions? Or any pics of installation? I might be interested in getting one also.
Old Apr 1, 2008 | 12:33 PM
TLewis4095's Avatar
Yes, it has both instructions & pics included.....but always feel free to contact me w/any questions & I will be happy to walk anyone through an install.
Old Apr 11, 2008 | 04:28 PM
99zman's Avatar
i just ordered my Rev Extreme catch can today from Tracy, hell of a nice guy he took the time to explain everything to me. i cant wait to get it. thanks alot.
