Air Pump - Is it Necessary????
Old Mar 9, 2008 | 09:07 PM
prowan's Avatar
Default Air Pump - Is it Necessary????
I just installed some LT headers on my car and I think I'm getting a leak through my Air pump connection. The car is not backfiring, but my wideband is not as stable as it used to be before the new install. Is it really necessary I have the Air pump connected?? What unwanted effects will I see if I remove it?? Any other ideas on what is causing my Wideband unstable? I did calibrate it and checked my header bolts for tightness. Thanks in advance!!
Old Mar 9, 2008 | 10:06 PM
LS1-NAVY's Avatar
take it out it will clean up the bay and get a block off plate
Old Mar 9, 2008 | 10:13 PM
sroach20's Avatar
it is extremely necessary. if it did not come that way from the factory i would have needed a different place to mount my siren when i threw the air **** in the trash. any exhaust leak before the narrow and wideband can cause improper readings. if you get rid of the air it will be easier to change plugs in the future.
Old Mar 9, 2008 | 10:14 PM
jetlag's Avatar
Um..what? No.
Old Mar 9, 2008 | 10:17 PM
sroach20's Avatar
Originally Posted by jetlag
Um..what? No.
read the whole thing, its called sarcasm.
Old Mar 9, 2008 | 11:25 PM
snake charmer's Avatar
for sure , get rid of it man . like said it will clean things up a good bit .
Old Mar 10, 2008 | 12:55 AM
waldershrek's Avatar
It isn't necessary from a performance stand point but emissions wise it would be. You will have to get the A.I.R. system tuned out after you remove it or you will get an SES light.
Old Mar 10, 2008 | 10:35 AM
Last C5's Avatar
And well done too. A siren??
Old Mar 10, 2008 | 10:45 AM
sroach20's Avatar
a siren for the alarm. with my vehicle being dropped, it would be a pita to get to it to disconnect it.
Old Mar 10, 2008 | 07:07 PM
prowan's Avatar
Thanks for the replies!! I will try and remove it and see what happens. Should I leave the flex hoses dangling, or should I remove the entire air pump unit and all hose???
Old Mar 10, 2008 | 07:17 PM
gold98Z28's Avatar
get rid of all of it. the hose just runs behind the intake and has one clamp to hold it. will come right out.
Old Mar 10, 2008 | 07:23 PM
SOMbitch's Avatar
I am too lazy to find you link but go to installuniversity and it's right there. Very simple.
Old Mar 10, 2008 | 08:39 PM
thebart455's Avatar
i just removed mine when i changed the intake manifold its quite simple u can get the block off plates pretty cheap at ls1speed.com
