6.0 to a 4l60e
Old Mar 13, 2008 | 09:07 AM
sum guy's Avatar
Default 6.0 to a 4l60e
I have a 5.3 bolted to a 4l60e in my 71 truck. Later this week I am going to switch out the 5.3 with a 6.0 is there anything special you have to do to bolt them up? I recall reading something about a spacer for the flywheel.
Old Mar 13, 2008 | 11:03 AM
Carshopinc.com's Avatar
LS1TECH Sponsor
You need to know if your 6.0 already has the spacer installed and if it uses a straight flexplate or a offset unit. Use the flexplate from your 5.3 but make sure your 6.0 does not have the spacer!
Old Apr 13, 2008 | 11:16 PM
MikeMoss's Avatar
do you know what years of the 6.0 came with the spacer?
Old Apr 14, 2008 | 11:52 AM
LS1TECH Sponsor
any motor with a 4l80e behind it will have the combo!
