5.3 Upgrade
Old Mar 17, 2008 | 05:58 PM
Syclone2982's Avatar
Default 5.3 Upgrade
Maybe this is the wrong thread sorry I am a newbie
I am taking a 5.3 out of a tahoe and going to due some internal upgradeing (cam and maybe heads)
But I am going to go ls6 intake and slp headers I dont know if i need injectors
I am curious what I need to do about wiring as far as throttle body or what throttle body I need to run (iff not stock) MAF (if i need to upgrade)
just some basic pointers or threads to read
Thanks in advance
Old Mar 17, 2008 | 07:07 PM
TLewis4095's Avatar
Thanks in advance
Lowest cost is to add the LS6 intake & a stock LS1/LS6 cam & run a LS1/LS6 ported TB. You will see a pretty nice improvment for very little $. Add a samll turbo for some boost & expect 600 plus HP.
We have good used take-out cams for $50 each plus shipping if you want one.
Old Mar 17, 2008 | 10:04 PM
sroach20's Avatar
you will need to do some rigging to make the ls6 intake work with truck accessories.
Old Mar 18, 2008 | 10:16 AM
What do you think power wise with cam intake and tb
And do you have any pull off intakes as well?
TB aftermarket or stock with port( i am guessing that is what you are refering to)
and what kind of riging am i going to have to do???
Old Mar 18, 2008 | 10:38 AM
ChevyThunder17's Avatar
May I recommend a stop over in performancetrucks.net? It's an affliate board; they are geared more toward trucks, not that we aren't here.
I did a 6.0 bottom end swap in my Avalanche along with a good cam, some long tube headers, stock 5.3 heads, stock truck intake manifold, stock catback, stock converter. I ran 15.1@90 MPH with it. It weighed 6100 lbs with me in it. The torque is produced was wonderful.
Old Mar 18, 2008 | 10:50 AM
sroach20's Avatar
if you want to use an ls6 intake you will need to swap to camaro accessories or take a camaro water pump and swap the truck pulley over. you can search on performancetrucks.net and read about it.
Old Mar 18, 2008 | 12:15 PM
silver-mod-o's Avatar
Custm2500's #1 Fan
I'd look over on performancetrucks...
There are plenty of writeups on how to do the truck intake --> LS6 intake swap, a lot of guys have done it.
Whats the motor going in?? It may be beneficial for you to keep the truck manifold and just mill the heads some with a cam and exhaust... Guys are running 11's on truck manifolds... on motor, in 4500+lb trucks... Its ugly, sure, but its not to be sneezed at. It flows better than the LS1 car manifold.
