**NEW** BBK LT's, and ORY **LOT's of PICS INSIDE**
#183
If you are doing motor mounts you will have have to move the A/C compressor and alternator forward. I think its the brackets that get in the way. The LT portion I pulled off-oil dipstick, plugs, wires, coil packs, old manifolds, y-pipe. I did not have to remove the starter, oil filter (HP-2006), steering knuckle. Driver side went in from the top and passenger from the bottom. My car really wasn't that high up either. Passenger side 02 didn't need an extension, but the drivers side does. I extended the drivers side and it seems to be working great. The two rear 02's will reach so I hooked them up for the hell of it.
#184
Forgot completely about these.
Not crazy we can't use a 3"-4" FM merge...
Has anybody looked into what options are out there for upgrading the Y? Hell, I would even consider cutting the end of the collector off so I can use whatever Y/X/H setup I want.
I would much rather run an X pipe that my exhaust guy usually makes us.. It is also 2.5" but it is very cheap and sounds amazing coupled with 1 chambers, great X and ground clearance.
What other headers does this Y pipe fit? I think it would be mighty hard to sell it.
#185
#188
#189
It goes in 3/4 of an inch but need to go 1 1/2. Tried to do sandpaper earlier and just could not get it. Will have to try again in the morning. Maybe do some more sanding on it. The stock stuff was pretty rusted.
Thanks.
Thanks.
#192
If the y pipe is 2.5" its gonna be a flop. Yeah, people are concerned about clearance but not to that extreme. Just my opinion.
If the y pipe is 3" and the headers and y pipe combo is that price on their site then they wont be able to keep them on the shelf.
Oh yeah, the tubes must also be 1.75. Looks like they are.
