Jet Hot Headers
Old Mar 23, 2008 | 04:24 PM
N2RACINGLS1's's Avatar
Default Jet Hot Headers
I went racing Saturday and on the last run it left hard on the footbrake at 3,000 RPM resulting in a 1.453 sixty foot it seemed to take forever for it to come down it ran a 10.80 at 123 MPH NA. The best run was a 1.445 sixty foot 10.759 at 123.59 MPH NA.
On the downside at the end of that run on the way down the return lane I noticed it was making a strange noise. When I got back to the pits to put the car in the trailer and opened the hood guess what I found the EGR tube was gone off of my Jet Hot driver side header. This ended the day on a sour note, not good a hole the size of a nickel in the header.
Has anyone had this happen to them? The headers have 1,000 miles on them and are 4 years old with the coating.
N2
Old Mar 23, 2008 | 05:30 PM
Order 66's Avatar
If you had the EGR blocked off it can and will happen. Very common. That is why getting race style with out EGR/Air tubes is the best.
Old Mar 23, 2008 | 07:01 PM
You are correct when I bought them they did not have the race version. The funny thing is the headers were open with only 18" turn downs.
Old Mar 23, 2008 | 07:38 PM
Order 66's Avatar
Just a weak point when they are blocked off. Just patch em up.
Old Mar 23, 2008 | 07:48 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
My FLP's did the same thing. I just laid some steel on it and put a bead all the way around. Never a peep after that.
Old Mar 23, 2008 | 07:55 PM
MIDTOWNSS's Avatar
Its common for that to happen. knock on wood ive had the same headers on my car for six years and no problems with them.
Old Mar 23, 2008 | 07:56 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mine did it after 5 years. So hope your luck hangs in there.
Old Mar 23, 2008 | 08:38 PM
It seems odd that with no exhaust on the car except for 18 inch turndowns that it would fell. I just hope I did not hurt the valve. I guess the tube/weld popped off when I let off at the top end. I know it made a full pass without skipping a beat.
When I rolled my window down to get my slip is when I heard something and got it back to the trailer and shut the engine off as quick as I could!
