True Duals or Cut Out
Old Mar 24, 2008 | 08:06 PM
ws6formula98's Avatar
Default True Duals or Cut Out
will i gain alot from true duals? rigth now i have Long tude headers, and off-road Y-pipe with a cut out and mangaflow catback.. My car make 420rwhp n/a and im spraying 150shot on top of that..is it worth spending 450 for some 3 in TPS true duals? or should i spend it on something else? thanks guys
Old Mar 25, 2008 | 12:58 AM
2000Hawk's Avatar
Well remember your going to probably lose a bit of ground clearance with the True Duals, but a plus is they sound amazing. The cut-outs will sound great to when they are open, and you can close them up when things get to loud for you. And best thing is the cut-outs are alot cheaper than if you get a True Dual set-up.
-Joel
Old Mar 25, 2008 | 01:12 AM
lemons12's Avatar
id want the sound..... TD
Old Mar 25, 2008 | 01:28 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Looks like you need some heads. I would save the money on duals.
Old Mar 25, 2008 | 11:30 PM
my cut out is always open... will i gain or lose any power with true duals?
Old Mar 26, 2008 | 09:48 AM
tylerdj's Avatar
If you went to a TD setup with a properly done X-merge then you would probably see some slight increase but not enough to warrant a change IMO. I would only do it in your case if you just wanted the sound of the duals. Like Orange said, I would just save that money towards heads.
Old Mar 26, 2008 | 10:19 AM
Duffster's Avatar
I had a 3" cutout on my flowmaster catback and gained MAYBE 3 RWHP via dyno results. With the LT switch and true duals, I got 38 RWHP. . . you're call
Old Mar 26, 2008 | 10:24 AM
Slvr00Bird's Avatar
Yea, long tubes do a lot though... I would stick to where you are and invest in something else..
I've actually seen some threads on here where guys mention that they actually lose hp from going from a setup like yours to true duals.. Something crazy happens with the back pressure in their cases I believe..
Anyway, you put down good numbers and even if there is a pony or two to be found there, it isn't enough to justify shelling out a ton of cash for trues IMO..
Old Mar 26, 2008 | 11:07 AM
Duffster's Avatar
thrifty shopping and doing alot of the work myself, I spent all of 475 for the FULL exhaust.
Good luck
Old Mar 26, 2008 | 07:35 PM
I love the way my exaust sounds rigth now..theres a dynomax bulet before the cut out, which makes it sound real clean and not all raspy...i wll spend my money towards something else.. thanks guys..
