O2 sensor questions
Old Mar 29, 2008 | 08:44 PM
superbee_68's Avatar
Default O2 sensor questions
I'm about to put headers and an off road y pipe on my 98 TA w/ 120,000 miles. I have already turned off the egr, air, and rear O2's, but I was wondering if I needed to change my front O2's? Do they wear out, or throw off readings with age? Are there better ones that are more accurate?
Thanks
Old Mar 29, 2008 | 09:25 PM
Unertl42's Avatar
I would change them if they are the original ones. Just get AC Delco O2s for the front and you might need wire extentions. You can get those at summit or the like
Old Mar 29, 2008 | 09:31 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Any sponsor carries the extensions.
Old Mar 29, 2008 | 09:56 PM
bczee's Avatar
many of them do.. I know Casper does and well as many others
http://www.casperselectronics.com/mm..._Code=CAMA9802
Old Mar 29, 2008 | 09:57 PM
sroach20's Avatar
get some ngk's made for a vette.
