hooker headers install
Old Mar 29, 2008 | 09:55 PM
Raptor_WS6's Avatar
Default hooker headers install
i am installing the hooker headers
am i suppose to use the bolts that they sent?
they only sent 12
and i ordered teh 02 version
i think i got them but the have three provisions'
2 are for the air, but what is the third? it came with a block off plate but they only sent 12 bolts instead of 14.
help??
Old Mar 29, 2008 | 10:08 PM
'99bluez's Avatar
they only sent 12
help??
there are 12 bolts for the headers. 6 for each side of the engine. There is 1 air on each side and 1 egr on the passenger side. EGR was onlt on 98-00 cars, not on 01-02 cars. Just block off the 1 on the header for egr since your car is a 2002. Just find some bolts at a local hardware store.
Old Mar 29, 2008 | 10:18 PM
Raptor_WS6's Avatar
thx, so should i use the hooker bolts even tho they are significantly shorter
Old Mar 29, 2008 | 10:25 PM
LS1crazy01's Avatar
I reused my stock bolts and gaskets with my qtp's. My buddy did the same with his hookers. And none of us have had any probs.
Old Mar 29, 2008 | 10:27 PM
Raptor_WS6's Avatar
great thx
Old Mar 29, 2008 | 10:57 PM
'99bluez's Avatar
like LS1 crazy said - reuse your stock bolts!! I just did headers a few weeks ago and reused the stock ones. Also yes you can reuse the stock gasket too - but if your car is over 50k they will be fairly worn out, then I would probably get new GM ones. They are only $20.
Old Mar 29, 2008 | 11:32 PM
LS1Z28_98's Avatar
I did mine and re-used the stock bolts and got new gaskets. I also deleted the EGR when I upgraded to a LS6 intake. I believe my kit came with block off plates for the EGR and the AIR. No bots for them as you would also use the stock ones to secure the block offs
Old Mar 30, 2008 | 01:13 AM
Formula_LS1's Avatar
I'm finishing up with my Hooker header install now...some tips...
- Get new gaskets...I went with Fel-Pro...only cost $10-15 and are much better quality than the ones in the kit. You could reuse the stock ones, but I recommend just buying new ones, especially if you have a car with higher mileage.
- DO NOT use the bolts that came with the headers. In my kit, I only had 11/12 bolts. The ones in the kit are WAY too short. You could reuse your stock ones...I went with the Stage 8 Locking Header bolts, which are very nice. Those were about $50.
- As for the block off plates, just reuse your stock bolts.
Old Mar 30, 2008 | 04:12 AM
Raptor_WS6's Avatar
i got new gaskets at the dealer,my bro works there
and as far as the bolts, i am going to look at them tomorrow to see whats up
Old Mar 30, 2008 | 09:38 PM
fastz99's Avatar
Which hooker headers did you get? Did you get the Comps or Super Comps?
Old Sep 6, 2008 | 02:00 PM
Nightrydass's Avatar
do the EGR block off plates come with the headers. We r doing a header install on my friends car and he doesn't know his *** from a hole in the ground so he doesn't kno what he has. He asked me to find out.
Old Sep 6, 2008 | 02:09 PM
94'BLKBRD's Avatar
The EGR block off plates don't come with the headers. You can make your own.
Old Sep 6, 2008 | 02:19 PM
or you can buy them...thanx.
that is what i thought, but i wanted to make sure.
Is the install pretty straight forward? I couldn't find a install guide on it. do you have to remove the starter or oil dipstick or anything? This is for a '00 Trans Am w/ the LS1 intake, EGR and ****.
Sorry if i seem a lil annoyed, but my friend has a habit of doing this ****.
Old Sep 6, 2008 | 02:46 PM
Predator's Avatar
You definitely have to remove the dipstick tube. There's a 15mm bolt that goes through the header flange plate into the head capturing a bracket for the dipstick tube. Then the dipstick tube just pulls out of the engine block. Don't forget to take the dipstick out of the tube when pulling the tube out of the engine block.
You shouldn't have to remove anything else although I've never installed Hookers. Good luck!
Old Sep 6, 2008 | 03:15 PM
Pete_Dragoon's Avatar
hell, hooker baby! GEt some from ws6store if you are worried about the quality of bolts. yeah, the other one is an egr prov like that dude said.
Old Sep 6, 2008 | 04:42 PM
thanks guys!
Old Sep 6, 2008 | 05:18 PM
Mikes96z's Avatar
The bolts Hooker includes are too short,
Old Sep 6, 2008 | 06:00 PM
krazy4's Avatar
Old threads F T W!!!
Old Sep 6, 2008 | 09:23 PM
the search function works!!!
Old Sep 7, 2008 | 12:51 AM
ReFtheMC's Avatar
Hahaha...
