vic jr & accufab = failed?
so im not sure if the ls6/stock ported tb will limit my power/flow with the new cam, i was thinking of goin with a 90/90 but since i wont be driving this on street (well sometimes) im leaning towards going with a vic jr./accufab 4150, theyre about the same price but the vic would benefit me more on the top end.
since its MAFless a speed density tune is required right? will the vic jr./accufab outperform the 90/90 at peak power? has anybody seen this intake setup on a 346? keep in mind this is not a street car so i care about streetability...
other related mods would be 4.56s/28" tires
any inputs, suggestions, tips? thanks
I hace a 242/252 590/600 on a 111lsa its cam only and runs like a champ big inprovement over the bbk. The motor is built for nitrous and has a 3500 nitrous convertor in it and still fills awsome on motor I cant wait to spray it.
If you go with the vic. dont go with to big of a tb you dont want to kill it. and if your going to spray it use a carb plate kit but call the people you bought it from because you will need a diffrent jet on the fuel side do to the pressure increase of a ls1 fuel system over a carb. Hope this helps
