!AIR with cats
Old Apr 1, 2008 | 06:47 PM
Formula_LS1's Avatar
Default !AIR with cats
I'm installing LT's with a catted Y...has high flow cats. Just wondering if removing the AIR system would have any negative impact on anything, especially on the cats. Thanks for the help.
Old Apr 1, 2008 | 07:51 PM
02silvaZ's Avatar
nope, it was used to heat up the stock cats, lt y-pipe cats are so far down the pipe it doesnt matter, AIR only ran for a couple of minutes at start-up and then shut off, it was just to pass sniffer tests
Old Apr 1, 2008 | 08:47 PM
lastcall190's Avatar
After 1.5 minutes the AIR system punches out for the day. Just rip it out and don't look back.
-J
Old Apr 1, 2008 | 10:22 PM
'99bluez's Avatar
+1 rip that **** out!!! Looks a lot cleaner and it is 1 less think you have to move in the future when changing plugs. Plus every bit of weight loss helps!
Old Apr 1, 2008 | 10:28 PM
Thanks for the replies guys...I'll definitely be taking it out. The pump is not out yet, but it is not connected. I've noticed that there is a gas smell when I start it up that goes away quickly. It's the same smell as the cars with the ORY have...but on my car it goes away pretty fast. Is that from the AIR pump being disconnected and the cats warming up?
