New LPP stainless Headers and Y
#281
Well I'm waiting for some install pictures and feedback on how peoples installs went. I worked really hard at trying to fix every issue and problem with the old design. And I'm anxious to see if it all paid off. I'm sure there may still be minor issues seeing how every F-body is different but I don't think there will be any more major issues. At least I hope not.
#282
Was there any fix to driver side header that angled up to much? Could I send it back and get one that wasn't angled? I am just asking I may not have any problem at all.
I have thought about selling the earlier version I bought and get a set of these. These look really nice.
#284
just installed mine. everything was great except for the second and third cylinder back on the driver side. i have some major primary to spark plug wire contact...i cant figure it out. any tips?
#286
Yes on the MSD wires. The stock wires will have issues with any headers. If you get the MSD wires you can bend the boots at any angle you want to miss the primaries.
#288
I've had MSD wires on my car since my first set of headers and still using them. And if you talk to anyone that has put headers on any car in the last 50 years they will tell you that stock wires don't work. It's just a fact with headers.
#289
alrighty....wheres the best place to pick up the MSD's? looking for black. link? thanks for your help. i drove an hour today to go get these headers because fedex forgot to put my box on their truck.....i wanted them pretty bad huh? thats why im so bummed. everythings done but those damn wires!
#290
#295
hmm wonder if i will have the same issue with my SLP. If so a Exhaust shop could open one up probably for free as it would take all of a min. to do
You would probably want to open up the intermediate pipe to go over the Y pipe. Might help you a bit more so there would be no exhaust leaks
#296
Yeah get a 6" long or so piece of 3" pipe, I have seen some pieces at autozone even, and put it over both ends, the pipe is reduced to fit in a 3" pipe so you need a short section of 3" pipe to make a coupler.
Also you may want to check whatever y pipe came off your car and hack a piece out of it to see if that will work.
#297
alright well heres what i did. took to borla intermediate pipe to my local exhaust guy to have it expanded. he said that typically those notches cut out on pipes are for them to expand and contract as you tighten them down (with band clamps, not saddle clamps). he was reluctant to expand it because he said usually pipes like to split up the sides where those notches are. i told him i didnt have much to lose, so he used a conical expander and got it opened up without splitting it. he told me if it was going to split, it would have at that point, and then took a 3" O.D. die and pressed it in the end to further expand it and make it perfectly round. took it home and it fit just fine! only problem now is i have a very slight exhaust leak from that joint. I had some really expensive 3" stainless band clamps that were too big, so I went to the local NAPA and they only had 2.5" (too small). SOOOO if you guys do this method, make sure you can get a hold of a 2 3/4" stainless band clamp to get the bitch sealed up tight! anyway, now its done aside from that 1 clamp.
-side note-
i have a buddy who is a kooks purist and he came over to tear these headers and y apart. he bent down to look at the merge collectors and y-pipe and after about 10 seconds of silence he stands up and says...."holy ****, those are f*ckin sexy".
we'll see if he ever gives me a hard time for savin a dime and going with a company that doesnt have a huge name
THANKS LPP for a superior product at an extremely affordable price.
if anyone has install questions, needs tips, pics, whatever...let me know.
-side note-
#299
Got a 2 3/4" "butt joint"(flat) band clamp and had to trim off about half and inch of the intermediate pipe . Got the bung plugs in and tightened the remaining clamps, and everythings done now.
#300
Got my headers in over the weekend, and they fit in like a glove. No notching or cutting of any kind.
One issue I did have however: I think on the next batch of headers, the flange should have the same hole size pattern as stock. Currently the holes are all the same size-7/16". On my stock manifolds, two holes were smaller in order to center-align the manifolds to the heads. For the headers, I had to use two studs with a steel dowel around them to align the headers to the heads.
Other than that, these things are fantastic!!
