L92 Swap into a Fbody, None of the PASS coils firing?
Ok my buddy did a L92 motor swap, we got the right sprocket in it and everything. He only has 1 of the 2 knock sensors hooked up and where he put it was right in the bolt hole where the AC pump used to go. He also switched the wires on the cam sensor. Now I shot a heat gun at it and the whole side is completely cold. Im not sure if its not getting fuel or spark, Im going to pull a plug and see if its wet. What could this be?
Edit: I forgot it has to be spark because it reeks like complete FUEL when its running.
