exhaust leak?
Old Apr 16, 2008 | 02:02 PM
eduardo's Avatar
Question exhaust leak?
does exhaust leak make me lose power. its leaking some from where the headers and y pipe join. also my y pipe bangs like crazy on the floorboard so does this maybe set off the knock sensor and pull timing.
Old Apr 16, 2008 | 02:13 PM
Moscosoalfredo's Avatar
do you have a buddy with a scanner!!!!!
Old Apr 16, 2008 | 02:25 PM
tylerdj's Avatar
Depending on how hard it's hitting it could be making the engine sense some knock. Easiest fix for that is to put a piece of heater hose in between the pipe and the floorboard. The leak could be letting cooler air into your exhaust which could affect your O2's readings and affect your A/F.
Old Apr 16, 2008 | 02:33 PM
eduardo's Avatar
wont the heater hose melt because of the heat. if not then ill go get this **** fixed. its kinda embrassing with all that banging. gave a girl a ride after class and she looked at me funny and said whats wrong with your car. thanks for the input guys
Old Apr 16, 2008 | 03:58 PM
tylerdj's Avatar
I actually used a piece of the AIR hose. Never had any issues with it.
Old Apr 16, 2008 | 04:00 PM
CAMAROZ28SS's Avatar
just get motor mounts. i have the same problem, heater hose is such a crappy fix.
Old Apr 16, 2008 | 04:02 PM
tylerdj's Avatar
There's also an exhaust bracket that some of the sponsors sell that is made specifically for the Y-pipe banging issue.
Old Apr 17, 2008 | 01:28 AM
LebaneseShowoff's Avatar
I had the same problem, i took my car to a "shop" for a quote and the guy didn't put blocks on the lift (car is lowered), so the idiot lifted the car on the y-pipe. Put a piece of rubber there and done.
