Switching exhaust...
- have y-pipe fabbed up (the self gutting QTP catted y-pipe is not an option)
- have duals run out back with cats (over or under axle? NJ roads suck *****)
- have dumps angled outward and add cats
Opinions and comments welcome. Thanks. I am going to v-band the ypipe/duals to header connection, i've had enough of these chincy band clamps.
-J
-J
The only thing I would do instead of adding the cats is add another set of mufflers before the tips (I've seen many pictures of this being done on here but can't find them at the moment). Then you could unbolt the rear section and have it as loud as it was before if you go to the track or anything.
Here's some pics of my new setup https://ls1tech.com/forums/showthrea...76#post9182576
-J
