True dual question..
Old Apr 21, 2008 | 07:29 PM
JustAFooL's Avatar
Default True dual question..
I have been wanting to put a true dual system on my car for a while.. Well, its time.. lol. I have a quick question though. Alot of the systems I have seen have really small, circular mufflers. I am looking at buying the Flowmaster Delta Force mufflers, which come in different sizes like 4"x10 and 3"x8". Does the size actually make a difference in sound or performance? And also, my local muffler shop was talking about just running 2 straight pipes off the header for each one. Most setups I have seen use a x-pipe.. Is this something I definately need to look into getting or is it just personal preference??
Thanks in advance,
Ryan
Old Apr 21, 2008 | 07:32 PM
Full-Force's Avatar
Some kind of crossover pipe will make a lil more power as well as tone down the sound.
You dont have alot of room for big mufflers so you may want to stick with the bullet type mufflers, 1 chambers, or the smaller 2 chamber that Flowmaster makes.
Old Apr 21, 2008 | 07:40 PM
JustAFooL's Avatar
Who makes a good "bullet" type muffler in a 1 chamber?? I think that flows definately have the best sound dumped, but what else is out there that really sounds good? My car also has a pro-kit.. that definately hurts.
Old Apr 21, 2008 | 07:43 PM
neeshSS's Avatar
I'm running 'sweet thunders' and i think they sound good. here's a little vid ...http://videos.streetfire.net/video/Z...aro_154312.htm
Old Apr 21, 2008 | 07:54 PM
JustAFooL's Avatar
So, I may be wrong here, but are 1 chamber flows typically smaller?? I read what Force said and to me, it sounded like he was saying I needed to get 1 chambers or bullets.. I have seen people running the flowmasters dumped, but I just wouldnt know where to start looking for the "bullets" at..
Old Apr 21, 2008 | 10:08 PM
94'BLKBRD's Avatar
Bullets- Magnaflow, Dynomax,Moroso Spiral Flows......just to name a few
I would go with a H-pipe true dual setup w/flowmaster single chamber mufflers
Old Apr 21, 2008 | 10:50 PM
mvvette97's Avatar
I run the Moroso Spiral flows on mine with an X pipe. I have a video in my signature if ya want to hear it..
Old Apr 21, 2008 | 11:25 PM
badass99ss's Avatar
I recommend Magnaflow. I had single chambers but I could not find a location for them over the axle that I liked. You could dump them or go under the axle, but being you are lowered like me I don't know if you would have the room. The measurements of the single chambers are 5.5in length, 3in thick, and 8in wide. Trust me I know. I tried every location to mount them.
https://ls1tech.com/forums/showthrea...241&highlight=
Here is the link to my Magnaflow set-up, if you read through it you will find the link to the single chamber set-up. Hope any of this helps.
Troy
Old Apr 22, 2008 | 12:19 AM
MrElectric03's Avatar
If you take the exhaust all the way out the back you have room for mufflers just before the tips. However I would suggest against flowmasters. They are notorious for robbing horsepower. I have seen many TD setups with magnaflows that can either sound really great with a loud tone or be quieter with a nice tone.
Old Apr 22, 2008 | 08:15 AM
tylerdj's Avatar
There's many people who have used those style of mufflers (magnaflow 4x9's, flowmaster 1 chambers) and it will give you a quieter tone than something such as the bullets.
Old Apr 22, 2008 | 01:15 PM
LS14U2NV's Avatar
magnaflow magnapacks is a nice muffler duals. my roommate has it on his ta with a orh pipe and sounds good. it has a really deep tone to it, will cruising it doesn't annoy you as some mufflers will do. but at wot it sounds insane.
Old Apr 22, 2008 | 02:00 PM
King Nothing's Avatar
i have the pro-kit as well, i have an h-pipe set-up for my true duals and yeah you need a crossover pipe. i ran it 2 pipes dumped before the axle and it was crazy loud, think nascar hahahaha catless with loudmouth resonators when i had him put the h in it quieted it down some and made it a deeper tone, then bringin it out the back quieted it down in the cabin.
Old Apr 22, 2008 | 06:50 PM
JustAFooL's Avatar
So, I guess what I should be asking is what mufflers are going to give me the most ground clearance along with a good, loud sound. I have a cutout right now, and it is pretty damn loud. I just really dont like the way the car sounds though with it uncapped.. I want the duals to show off the cam.
Old Apr 22, 2008 | 07:12 PM
02silvaZ's Avatar
i recommend bullets since you are lowered
Old Apr 22, 2008 | 07:13 PM
JustAFooL's Avatar
Is there any sponsors on here that sell "bullets"??
Old Apr 22, 2008 | 07:52 PM
tylerdj's Avatar
Texas Speed has a pre-made true dual setup with bullet, sprial flow, and sweet thunder mufflers if you're looking for the whole setup.
Old Apr 22, 2008 | 10:16 PM
JustAFooL's Avatar
Nah, I am really just looking for the mufflers man..
Old Apr 22, 2008 | 10:52 PM
94'BLKBRD's Avatar
Check ebay for the mufflers
Old Apr 22, 2008 | 11:06 PM
ms4z28's Avatar
ya i got dynomax bullet style on mine u could find something like that in summit or jegs i had the slp loud mouth and its a little bit quieter but it s alot deeper and sounds so much better
Old Apr 22, 2008 | 11:11 PM
mvvette97's Avatar
the spiral flow is also a bullet style so it had great clearence but it's baffled, kinda.
