What else can I do???
Old Apr 22, 2008 | 09:49 PM
0235SS93's Avatar
Default What else can I do???
I have an 02 35th LE A4 that has the following:
SLP LT Coated Headers w/ Catted Y-Pipe
SLP CME
SLP BLACKWING LID
SLP 85mm MAF
SLP COLD AIR INDUCTION
K&N Drop-In
TB Bypass
P&P TB
Street Tune
I am still debating installing a UD Pulley, and an electric water pump is out of the qeustion, but are there any more bolt-ons I can do to add some ponies? I don't want to do H/C and installing a FAST would be almost pointless. Thanks!!!
Old Apr 23, 2008 | 10:06 AM
Striped02WS6's Avatar
i didnt see you mention nitrous in there anywhere....maybe a small shot of the squeeze to get your jollies off
Old Apr 23, 2008 | 10:16 AM
Unertl42's Avatar
a stall conv, that would make it more fun to drive
Old Apr 23, 2008 | 10:52 AM
180ls1's Avatar
cat delete pipes, they should be good for 5-7 horsepower and maybe just a bit more torque. Just make them removable so you can put the cats in or pull them out using band clamps.
Old Apr 23, 2008 | 10:55 AM
teke184's Avatar
gears and a converter would be the next step for an auto.
suspension would be the next "easy" thing to do. poly torque arm bushing, lower control arms and a panhard bar would tighten the suspension up. subframe connectors would also be a BIG help.
Old Apr 23, 2008 | 12:15 PM
95GreenZ28's Avatar
X2. Stall that biatch
Old Apr 23, 2008 | 02:26 PM
tennz28's Avatar
Stall and cutout, maybe dual cutouts?
Old Apr 23, 2008 | 02:31 PM
94'BLKBRD's Avatar
gears and a stall conv
Old Apr 23, 2008 | 05:11 PM
0235SS93's Avatar
Ok Thanks!!!
Old Apr 23, 2008 | 05:15 PM
joker machine's Avatar
Converter
Old Apr 23, 2008 | 05:23 PM
RoDan's Avatar
here is what i would do, in this order:
1) LCAs
2) Converter (do NOT go cheap here, i'd go precision vig, or yank)
3) Cutout
then maybe consider gears depending on how much you drive it on the highway. If you car is a 2.73 car then for sure get gears, if it is 3.23 then I would probably wait.
